flymco753
Re: Indianapolis Aviation Thread
Fri Sep 15, 2017 9:18 pm
Midwestindy wrote:
DL MCO-IND-89.5%
Time for this flight to either go 2x daily or upgauged to a 717.
Midwestindy
Fri Sep 15, 2017 9:46 pm
flymco753 wrote:
Midwestindy wrote:
DL MCO-IND-89.5%
I agree! Has this route ever been 2x daily, I feel like it has...
EDIT: Forgot to add
WN SAN-IND 91.2%
flymco753
Fri Sep 15, 2017 10:05 pm
Midwestindy wrote:
flymco753 wrote:
Midwestindy wrote:
DL MCO-IND-89.5%
Never, I was there when the route started and it's never gone 2x daily, at least on the days I'm there. Maybe back in the NW days?
Indy
Fri Sep 15, 2017 10:54 pm
stlgph wrote:
Right now Delta's CDG-IND flight isn't even on the ground, as scheduled, for a full 2 hours. Given the turn around time, I see towing it out and over another gate as being very unlikely, but, could happen (hell, it's happened at JFK). If DL's regularly operations to Europe cause delays for other international arrivals in the afternoon, A3 can easily be added to the customs area, if it is really needed.
If there is a delay at international arrivals at IND because of this one flight then something really went sideways. There are two international gates and I think 6 of 7 days of the week there will be no more than two international flights. I think Saturday will be the exception but even then I think you are looking at 3 flights. I think you'd need some kind of crazy sequence of events to cause all three flights to get to the airport in the span of an hour or so. The chances of that happening are slim.
Indy
Fri Sep 15, 2017 10:55 pm
It at one point went 3x weekly during NW days if memory serves me correct. Not sure how long that lasted. I think it was brief.
flymco753
Fri Sep 15, 2017 10:59 pm
Well you have to think, with no feed on the IND end, and the market size in correlation to equipment size, I think at this time the best move would be to go 2x daily with RJ's, jumping the gun with 1 aircraft at a larger size could either not produce the revenue that DL wants, I'd say 2 -700's could work.
stlgph
Fri Sep 15, 2017 11:24 pm
As I recall Northwest started IND-MCO with one daily DC9, and then it had jumped up after a short time to two, then three daily, sometimes with a DC9/DC9/CRJ mix, just depending on whatever they felt like running at the time.
flymco753
Fri Sep 15, 2017 11:37 pm
That's why I think it'd be smart to start out at 2x RJ or daily 717 as opposed to anything bigger, with F9 already on it, WN with majority of the share, and G4 over at SFB, I don't see B6 or NK jumping on it, so it makes it pretty feasible for DL to add a few more seats.
Midwestindy
Fri Sep 15, 2017 11:41 pm
Do you mean 3x daily?
I think it should be limited to 2x daily CR7 during Winter Break/Spring Break/peak Summer and if it does well then make it year round 2x daily. However, DL still routes a large amount of IND-MCO traffic through ATL. Furthermore, the 6 am departure is good for some and not all, especially those traveling with younger children, 2x daily with an afternoon/evening departure would probably be more attractive to a lot of IND-MCO travelers.
flymco753
Fri Sep 15, 2017 11:51 pm
I can agree with that, the other flight could be an evening departure from IND and get into MCO around 8:30 or so to give families time to settle in their resorts and what not, and leave MCO around 3:30 so families are home in time for school and work the next day. Now lets sit and wait to see if it comes to fruition,
Midwestindy
Sat Sep 16, 2017 12:44 pm
Here are some numbers on connecting pax through IND
Connecting passengers based on % of enplaned passengers
1990-28.4% 809,599-USair
1992-11%-USair
1995-14.6% 491,811-USair/ATA?
2000-8.8% 340,086-ATA
2005-13.3% 568,065-NWA peak
2009-8%
2010-5.5% 207,023
2011-3.7% 139,508
2012-4.6%-170,611
2013-3.9%-141,870
2014-6.1%-224,644-DL pike?
2015-4.1%-162,871
2016-4.3%-180,656
Indy
Sat Sep 16, 2017 2:26 pm
1992-11%-USair
2009-8%
2010-5.5% 207,023
2011-3.7% 139,508
2012-4.6%-170,611
2013-3.9%-141,870
2015-4.1%-162,871
2016-4.3%-180,656
You really find the most interesting numbers :-) Can you imagine that old D concourse in 1990? US at one point had nearly 150 flights a day. That concourse must have been so badly overcrowded. The A concourse during the height of the NWA days was pretty bad too.
indygs
Sat Sep 16, 2017 3:01 pm
Wow, AS is doing mighty well with SEA-IND.
And I still don't understand WN getting rid of DCA-IND. They have 86% LF with flight times that are not ideal for a business traveler. I always end up flying WN on the way out and AA on the way back so I can get a full day's work in DC. If they'd altered the fight times a bit I think they'd continue to do well on the route.
stlgph
Sat Sep 16, 2017 3:07 pm
The D Concourse in the US Air days wasn't that bad. A majority of the flights were 19 seaters and everyone would go downstairs and pass through gate 5A and then get walked out from the terminal to the sitting planes, right by where the "Courier Company," sits on Google maps now. The jets, of course, were parked at the gates, and US Air ran a "comfortable" schedule where jets pretty much came and went as scheduled and even in the times of delays, it was rare someone would have to sit out on the tarmac to get into a gate, and then once it did happen, there was a mad rush to do a turn in 30 minutes.
I remember in the 80's and 90's all the concourses at the time, despite letting every non-ticketed relative through security, there were never really issues of lines of too many people in the concourses, or even at the security check point.
After those security changes came through, there were delays with the security lines. When NWA came along hot and heavy in the A concourse, there were running with a number of 50 seaters, as opposed to 19 seaters, and less physical space than Concourse D.
FLYKTPA
Sat Sep 16, 2017 3:17 pm
I have a feeling that they only get good loads during the summer on IND-DCA. The winter is probably scary load-wise.
Midwestindy
Sat Sep 16, 2017 3:54 pm
YOY the flight is doing a lot better than last year
WN DCA-IND Passengers per month 2016 vs. 2017---LF 2016 vs 2017---Frequencies 2016 vs 2017
JAN 3499 vs. 4909 +8 frequencies
LF 49.9% vs 60.2%
FEB 3555 vs 4311 + 3 frequencies
LF 50.7% vs 57.97%
MAR 4867 vs 6397 +2 frequencies
LF 63.0% vs 79.88%
APR 5212 vs 6406 - 1 frequency
LF 67.49% vs 84.5%
MAY 5958 vs 6314 - 2 frequencies
LF 69.44% vs 76.13%
JUN 5137 vs 6883 + 5 frequencies
LF 70.4% vs 85.95%
I wouldn't be surprised if this route comes back in 2018/2019
910A
Sat Sep 16, 2017 11:43 pm
An Atlas 744 will be spending the night/morning Sept 16 to Sep 17 after dropping off the Arizona Cardinals.
Midwestindy
Sun Sep 17, 2017 1:41 am
Thanks for the heads up, now all we need to do is get BA to fly it into IND :D
Indy
Sun Sep 17, 2017 2:29 am
I'd take Condor Airlines to Frankfurt or Air Berlin to Dusseldorf :-)
zackary747
Sun Sep 17, 2017 5:08 am
If I am not mistaken, Air Berlin won't be around much longer. They filed for insolvency.
Indy
Sun Sep 17, 2017 9:49 pm
I saw that but didn't know how it compares to U.S. bankruptcies. Didn't know if it was reorganization or liquidation.
Midwestindy
Sun Sep 17, 2017 10:00 pm
Any chance IND gets in on the F9 announcement, especially considering they seem to be up to something in IND?
CUN-IND? SEA/SAN-IND?PHX-IND?There aren't many options they can tap into...
zackary747
Mon Sep 18, 2017 1:15 am
Do you know when F9 announces anything?
If they start CUN again I hope they choose Friday. Nobody flies that on Friday.
Midwestindy
Mon Sep 18, 2017 1:20 am
This Tuesday, is when they are announcing new routes!
stl07
Mon Sep 18, 2017 1:25 am
Didn't they already publish in advanced what rotes they were going to add?
zackary747
Mon Sep 18, 2017 1:37 am
Thanks for the memo! I wanted to mention that I personally think DFW needs ULCC service. Although I think NK would be better off on that route rather than F9.
Midwestindy
Mon Sep 18, 2017 1:49 am
Nope, COS and SJC have said F9 has an announcement about new routes (in other words in addition to what they have already announced) on Tuesday. So, I expect to see the list of other airports with announcements on Tuesday will grow as well by this time tomorrow...
stl07
Mon Sep 18, 2017 1:57 am
So just to clarify this is in addition to the routes they already said they would announce on Tuesday?
Midwestindy
Mon Sep 18, 2017 2:02 am
I'm confused? What routes did they say they would announce Tuesday?
stl07
Mon Sep 18, 2017 3:03 am
https://www.usatoday.com/story/travel/flights/todayinthesky/2017/07/18/blockbuster-expansion-frontier-add-21-cities-85-routes/488214001/
all routes without a date stamp are for Tuesday
Midwestindy
Mon Sep 18, 2017 3:10 am
Oh, that is what you meant. Yeah, supposedly there will be additional routes announced in addition to the other 85 new routes they announced in July...
stl07
Wow quite an expansion then.
flymco753
Mon Sep 18, 2017 3:12 am
Some of those 85 in which make almost no sense, lol. Gotta love what's going on at F9.
Indy
Mon Sep 18, 2017 3:16 am
So this summer F9 took a hand full of darts and threw them at the dart board. Now they are getting ready for their next hand full of darts. I just can't get excited about anything F9 announces.
Midwestindy
Mon Sep 18, 2017 3:21 am
Excitement or not, I feel like there is a chance IND could get in on some of the action, I am just not sure to where....
Indy
Mon Sep 18, 2017 3:46 am
Grab some darts :-)
atypical
Mon Sep 18, 2017 7:02 am
F9 has to be dumping as many routes as they are adding or else they are getting tons of aircraft in. I can't get excited about a route that can go away as fast as it arrived. F9 makes G4 look like the pinnacle of stability.
Indy
Tue Sep 19, 2017 1:59 am
Does anyone know the exact date/time IND-CDG will be bookable? I plan to be on that flight :-)
cvgComair
Tue Sep 19, 2017 2:51 am
The schedule is updated on Saturdays and this route will be loaded on September 23. I think it loads at 12:00am EST, but it might be a little later in the morning.
Indy
Tue Sep 19, 2017 3:09 am
Found out from DL it loads at midnight on the 23rd.
Indy
Tue Sep 19, 2017 4:36 am
I'm looking at CDG prices online and they are ridiculous. Checked CVG-CDG for May 24/31 and $1443 r/t. Also, why aren't there any Premium Economy seats available for purchase despite the fact the flight is empty still?
Edit: Disregard the premium economy issue. Despite the fact the flight listing acts as if the cabin isn't available, you can select a premium economy seat during booking. Glitch in the flight listing?
zackary747
Tue Sep 19, 2017 7:44 am
So, about that F9 concourse A move bid thing. It ends today at 3 PM (The bidding process). Kinda interesting that's the same day Frontier is adding routes. We shall see what happens.
Midwestindy
Wed Sep 20, 2017 12:32 am
Nada, I suspect F9 is moving to A to make room for G4, WN, or a new carrier (SY or NK). I doubt F9 will add much in the future, and they have no reason to really, so most of the ULCC growth will come from G4 who seem really interested in the IND market. I was at the Colts game on Sunday and G4 had advertisements on the video board, and during a timeout, they even sponsored a game on the field to win free tickets to JAX. Lately, I have been hearing a lot of radio ads as well. G4 has said they will add more routes out of IND by the end of the year, probably LAX and SJU and likely a few others. I would guess that any growth in the near future for IND will come from either, G4, WN, DL, or AS...
zackary747
Wed Sep 20, 2017 12:56 am
Yeah, you're probably right about that. I kept telling to myself Frontier needs to focus on FL and the west coast, and once they started to do that the routes have been stable. MCO is still running, RSW seasonal is coming back for the 4th year, LAS is looking well, and I am sure TPA will do well as it is a similar market to RSW and MCO. And well, DEN is DEN. I agree F9 is pretty much maxed out here unless they do further commitment like G4 is doing, which I don't see that happening. I looked at the F9 loads for PHL and they were pretty good overall, but F9 makes weird decisions sometimes. I think NK would do better on a route like that TBH. I am really excited to see what G4 is going to announce. We have to compete with CVG on the ULCC level a bit better. I always told people, if it's not FL. or the west coast leave F9 out of it and let G4, SY, WN, or NK handle routes like that.
Also, AS was giving a trip out to SEA just like G4 was doing for JAX.
As far as that IND-CUN F9 rumor goes. I guess we'll find out by the time they move to A3. Time will tell.
Midwestindy
Thu Sep 21, 2017 2:27 am
For those wondering about the Customs Facility in IND, I have some extra info (some of which I may or may not have mentioned before).
Gate situation is pretty well known:
Each concourse provides access to 20 gates
Aircraft gates can accommodate a complete range of narrow-body and wide-body aircraft, including regional jet aircraft with passenger boarding bridge access.
Inboard gates can accept narrow-body aircraft up to B757
Outboard gates can accept both narrow-body and wide-body aircraft (B767, B787 and B777 aircraft)
2 international gates on the south concourse (Concourse A) can accommodate one A380 aircraft
International Facilities
24,220 SF Federal Inspection Services (Customs) Area
6 Immigration and Naturalization Service (INS) positions
Can process 400 passengers per hour
Speaking of customs and international flights, with regards to a flight to LON in the future (excluding DY/D8), would BA or DL be more likely.
When asked about service to London this is what the airport said, "It depends on the popularity of the Paris route, Stone said. If it’s successful, London could be a possibility."
So, that kind of makes it sound as if DL would be the one to add a LHR flight if everything goes according to plan with the CDG flight, rather than BA....
Indy
Thu Sep 21, 2017 5:13 am
What, from that quote, leads you to believe from that comment that DL would be more likely to add LHR over BA?
Midwestindy
Thu Sep 21, 2017 10:02 am
Maybe I am reading too much into it, but I took it to mean that if DL has success on the CDG route, they will look to add LHR as well. Obviously, you can interpret that many ways, but since IND is a part of DL's "focus city strategy" it could happen. Also, I don't know how interested BA would be considering they probably wouldn't get great incentives since IND already has TATL service. It also would be hard for BA to enter the market later on, for obvious reasons. For example, you don't see BA at CVG, PIT, PDX, DTW, MSP, and SLC partially because of DL.
indygs
Thu Sep 21, 2017 1:14 pm
Interestingly, DL is now saying the CDG route will run daily from IND and then drop to 5X weekly. I thought initially it would start as 3X per week. Details can be found here:
http://news.delta.com/delta-s-trans-atl ... stinations
stlgph
Thu Sep 21, 2017 2:39 pm
Not at all surprised they are doing daily in the summer. Nice to see it will be 5 weekly.
Midwestindy
Thu Sep 21, 2017 3:18 pm
Glad this was DL and not BA/WW/FI/DY/D8 that provided IND its first TATL link, DL provides more frequency and capacity than any of those carriers would offer IND. Great to see it go 5x weekly instead of 3x weekly as well....
