AirportRival wrote:Just one or two more for Allegiant then they should be done. American is sending 18 CRJ's to CVG from what I've heard.
https://eidaeg.by3302.livefilestore.com ... pmode=none
I tried embedding the photo but a.net doesn't seem to like that so just the link is posted above.
cvgComair wrote:DHL is sending its SJO-MIA flight to CVG instead: https://flightaware.com/live/flight/ABX902
cvgComair wrote:AirportRival wrote:Just one or two more for Allegiant then they should be done. American is sending 18 CRJ's to CVG from what I've heard.
I noticed they were even shuttling in aircraft from other midwestern cities, it's nice to see so many Allegiant aircraft at CVG! Do you know how long they plan on staying?
cvgComair wrote:Article just out about how Concourse A does not have enough room a peak hours for the increasing amount of flights. Apparently the Concourse is expected to reach maximum capacity as soon as this summer and CVG needs more gates if any of the carriers want to add more flights. The renovations to open gates A1/2/3/5 just went up for bidding with an estimated cost of $10.4 million. This includes renovating the gate areas and upgrading the baggage systems in the Concourse. I really wonder how soon they will start working on expanding Concourse A, because they are going to need it:
Another issue is that Concourse A was built in 1984, making it 33 years old! The concourse has seen many renovations and is getting quite old and the article mentioned that CVG might need to tear it down completely in order to fix/upgrade the baggage, electrical, and structural systems.
ADrum23 wrote:To redo my above post about the Concourse A expansion (since I can't delete it), has CVG ever considered demolishing both Concourses A and B and building one new terminal building in it's place that can house all the gates (as well as connect to the ticketing and security building above ground)? This could eliminate the underground walkway/train and provide more convenience for passengers. After DL's lease on Concourse B expires in 2020, they should seriously consider that.
Cvgspotter15 wrote:ADrum23 wrote:To redo my above post about the Concourse A expansion (since I can't delete it), has CVG ever considered demolishing both Concourses A and B and building one new terminal building in it's place that can house all the gates (as well as connect to the ticketing and security building above ground)? This could eliminate the underground walkway/train and provide more convenience for passengers. After DL's lease on Concourse B expires in 2020, they should seriously consider that.
Yea that's the master plan
cvgComair wrote:Cvgspotter15 wrote:ADrum23 wrote:To redo my above post about the Concourse A expansion (since I can't delete it), has CVG ever considered demolishing both Concourses A and B and building one new terminal building in it's place that can house all the gates (as well as connect to the ticketing and security building above ground)? This could eliminate the underground walkway/train and provide more convenience for passengers. After DL's lease on Concourse B expires in 2020, they should seriously consider that.
Yep, that is the plan, except the train will be kept. In the previous master plan they determined it would hinder aircraft movement, plus they want the train to take passengers over to a new international arrivals facility in the main terminal building once Concourse B comes down.
ADrum23 wrote:cvgComair wrote:Cvgspotter15 wrote:Yea that's the master plan
Sorry, but I'm not quite following. Why would the train be needed if both concourses are demolished and a single, unified terminal that is connected above ground to the ticketing/security area is constructed? Do you have a link where they describe this?
cvgComair wrote:ADrum23 wrote:cvgComair wrote:Yep, that is the plan, except the train will be kept. In the previous master plan they determined it would hinder aircraft movement, plus they want the train to take passengers over to a new international arrivals facility in the main terminal building once Concourse B comes down.
It's essentially a replace of A, but there is still an underground connection.
Here are the renderings from 2013: https://www.cvgairport.com/docs/default ... f?sfvrsn=2
There is a lot more, but the plan has been removed from their website because the 2050 master plan will replace it. There are going to be a lot of changes, so this is not the best plan to go off of, it is likely they are planning a different terminal layout.
Here is a rendering if they go with a simple expansion of Concourse A, this was the original plan, obviously C is gone and D will never be built: http://www.airportsites.net/cvgpart150m ... 0406-3.pdf
This is my rendering of the Concourse A expansion without Concourse B:
ADrum23 wrote:Those are not quite what I was thinking. What I was thinking was more along the lines of what the Landside Z and X alternatives provide on page 5-11 of this document https://www.cvgairport.com/docs/default-source/master-plan-report/7-alternatives.pdf?sfvrsn=2
It would be nice to basically demolish the remaining structures and start from scratch, constructing a brand new state-of-the-art terminal with above-ground connections to the ticketing/baggage claim/security building. Hopefully, the 2050 master plan comes out soon and we'll see what they have in store.
cvgComair wrote:
In the doc, they explain they would prefer to have no over ground connections for better aircraft flow
In that case, the status quo (current) layout is acceptable (Concourse A and B with a underground train connecting them), however, both Concourses should be demolished and rebuilt/expanded to modern standards.
Are they serious about getting rid of Concourse B and building one, giant Concourse A that can handle all of the airline operations? If DL keeps their hub and WN expands (both of which I think are fairly likely), I'm not sure you can fit everyone in the Concourse A expansion as proposed.
The outlook in 2012 when they made that plan was waaaayyyy different than the CVG today. At that time CVG had 0 LCC's, DHL had not expanded yet, DL was still making huge cuts every year, and US/AA/UA were pulling back service. The new plan should be so vastly different that the 2035 master plan is effectively useless, which is why they started a new master plan 5 years after the old one came out. Nothing in that plan is serious except building the rental car area and widening the runways.
"This is a result of Network turning their efforts to "focus" cities. These are cities that are underserved and are not a hub for competitors. The model for DL was RDU. In short order, we add ~20 non-stops per peak day (often only 1 flight to many hubs) and a transatlantic flight to CDG, AMS or LHR. Can't talk specifics on this open forum. Think of large cities, near competitor hubs that we currently have only 4x service each day to a couple of our hubs. Austin would fit that description and we have already announced increased service. There are at least 6 others that are being considered. You will see AMS flights to new cities announced later this Fall."
cvgComair wrote:Delta has cut CVG-MEM effecting November 3rd. I am still unclear why they thought putting the CRJ-900 on the route and eliminating most connecting options was a good idea. Back in June 2016 the route was 2x/CRJ, it had a 81% LF, currently, it's running at less than 50%. It actually is one of the stronger small business routes from Cincinnati, it looks like a casualty of Delta's faulty scheduling, not lower passenger demand.
It appears the CRJ-900 will be moving over to CVG-MCI for the evening turn. I guess it is possible that Delta plans to bring back the route in the spring on a CRJ-200, but has not figured out the routing, however, given their continued cutdown of MEM, I think it's unlikely.
Ultimate Air Shuttle has been musing adding Memphis, so I expect they will add that in short order.
Midwestindy wrote:I think BNA/XNA/STL-CVG might be in trouble as well, JAN-MAY average LF for comparison on MEM-CVG was at 63.2% LF but *May '17 LF 28.2%
BNA-CVG average LF was 51.5% *Jan 30.0%
XNA-CVG average LF was 53.9% Jan 42.5%
STL-CVG average LF was 55.4% Jan/Feb lower 40s
Less likely BDL-CVG average LF was 57.3% *Jan 31.1%
I understand that fares on these routes are high, but I mean....
cvgComair wrote:His numbers are January-May and yours are June though.Midwestindy wrote:I think BNA/XNA/STL-CVG might be in trouble as well, JAN-MAY average LF for comparison on MEM-CVG was at 63.2% LF but *May '17 LF 28.2%
I agree, DL reducing frequency on these routes has killed connection opportunities and same-day business travel demand. I think XNA is probably safe because of P&G, but I am not so sure about the others. DL's changing of these routes from 2x/CRJ to 1x/CR7/9 was not a good idea, the 2x is really necessary to keep up demand. It is beyond me why they did not replace the CRJ-200's on CVG-RDU/ORD/BWI/CLT/PHL/YYZ and keep the remaining CRJ-200's on these smaller routes. It would have eliminated the same number of CRJ-200's.
Just for comparison, here was June 2016 when all these routes had more frequency:
CVG-XNA: 60%
CVG-BDL: 63%
CVG-STL: 76%
CVG-MEM: 81%
CVG-BNA: 80%
CVG-MKE: 74%
I think the numbers speak for themselves...
cledaybuck wrote:cvgComair wrote:His numbers are January-May and yours are June though.Midwestindy wrote:I think BNA/XNA/STL-CVG might be in trouble as well, JAN-MAY average LF for comparison on MEM-CVG was at 63.2% LF but *May '17 LF 28.2%
CVG-XNA: 60%
CVG-BDL: 63%
CVG-STL: 76%
CVG-MEM: 81%
CVG-BNA: 80%
CVG-MKE: 74%
Jshank83 wrote:Those drop off in numbers are crazy. I will say I rarely see CVG as a connection option anymore and if I do it seems like it is more expensive or a longer layover. At least it is still 2x daily. I have noticed they changed the pricing to where it is much cheaper to book a RT than just a one way or 2 separate one ways. I don't remember it being like that before for that route.
Midwestindy wrote:Jshank83 wrote:Those drop off in numbers are crazy. I will say I rarely see CVG as a connection option anymore and if I do it seems like it is more expensive or a longer layover. At least it is still 2x daily. I have noticed they changed the pricing to where it is much cheaper to book a RT than just a one way or 2 separate one ways. I don't remember it being like that before for that route.
This is interesting, I don't think DL can afford to cut very much more out of CVG, or else it will drop LFs across the board.
Routes like YYZ-CVG Jan-Feb 40.66% LF (*Jan 27% LF), EWR-CVG Jan-May 48.3% LF, and STL/BNA/XNA/BDL are treading water
Routes like RDU/MCI/ORD/DCA/PHL/MKE/DFW/IAH/CLT are doing fine, but some are almost empty during the winter months.
I think this shows DL is at least somewhat committed to CVG, or else they wouldn't have kept some of these routes around.
ADrum23 wrote:Midwestindy wrote:Jshank83 wrote:Those drop off in numbers are crazy. I will say I rarely see CVG as a connection option anymore and if I do it seems like it is more expensive or a longer layover. At least it is still 2x daily. I have noticed they changed the pricing to where it is much cheaper to book a RT than just a one way or 2 separate one ways. I don't remember it being like that before for that route.
This is precisely the reason I don't understand why DL insists on keeping their CVG "hub". Those numbers don't look good, they seem to be losing money. But as you said, if they cut any further, they will drop LFs.
This reinforces the reason why I think it would be beneficial to both CVG and DL if DL would just formally close the CVG hub. Thanks to other carriers coming in, CVG wouldn't lose much at this point because if DL closed, carriers like WN would significantly expand (they probably expand in the coming years regardless).
Alternatively, as I mentioned a while ago, DL can simply cut all the remaining connections out of CVG and focus on being a pure O&D hub/focus city.
cvgComair wrote:G4 is making some big upgauges at CVG next Spring (listed in times per week):
CVG-JAX/MSY/SAV/AUS/AZA frequency increased from 2 to 3x/week
CVG-VPS frequency increased from 2 to 4x/week
CVG-SFB/PIE/FLL/PGD frequency increased from 7 to 8x/week
Based on my calcs below, G4 will operate 86 flights/week, which is an increase by 17 flights/week for '16/'17 YOY!
MYR - 0
SJU - 1
BWI - 2
DEN - 2
PVD - 2
RDU - 2
PVD - 2
RDU - 2
DEN - 2
AZA - 3
JAX - 3
MSY - 3
SAV - 3
AUS - 3
AUS - 3
AZA - 3
LAX - 4
VPS - 4
EWR - 5
LAS - 5
SFB - 8
PIE - 8
FLL - 8
PGD - 8
Midwestindy wrote:cvgComair wrote:G4 is making some big upgauges at CVG next Spring (listed in times per week):
MYR - 0
SJU - 1
BWI - 2
DEN - 2
PVD - 2
RDU - 2
PVD - 2
RDU - 2
DEN - 2
AZA - 3
JAX - 3
MSY - 3
SAV - 3
AUS - 3
AUS - 3
AZA - 3
LAX - 4
VPS - 4
EWR - 5
LAS - 5
SFB - 8
PIE - 8
FLL - 8
PGD - 8
Doesn't G4 have some more announcements for the spring coming up, or are these finalized
knope2001 wrote:Until roughly a year or so ago Delta was pretty tightly banked in Cincinnati (outside of flights to big hubs like ATL, LGA, DTW, MSP). That has changed and it's definitely having an effect.
With fewer connections to bolster yields I fear we'll see more routes struggle, unfortunately.
Midwestindy wrote:knope2001 wrote:Until roughly a year or so ago Delta was pretty tightly banked in Cincinnati (outside of flights to big hubs like ATL, LGA, DTW, MSP). That has changed and it's definitely having an effect.
It's a shame, and it's hard to see the reasoning behind some of it...
knope2001 wrote:My quick tally only found five fewer weekday departures in 2017 versus 2015 so it's not liek a drastic cut in flights is the culprit. It's fewer connecting opportunities.
AirportRival wrote:The sad part about this cut is that another airline that currently flies to CVG is not likely to add it back. Ultimate Air Shuttle could possibly add it and would probably do well on it but they fly out of LUK and have been slow about adding new cities and growing.
Cvgspotter15 wrote:Lots of diversion from ATL at CVG currently, from what I can see there are 3 764s 1 a330 and 1 763 as well as a CRJ9 752 and 738.
jplatts wrote:Midwestindy wrote:knope2001 wrote:Until roughly a year or so ago Delta was pretty tightly banked in Cincinnati (outside of flights to big hubs like ATL, LGA, DTW, MSP). That has changed and it's definitely having an effect.
Southwest has nonstop service from MDW to CVG and all of the East Coast destinations that Delta serves nonstop out of CVG, with the exception of JFK (but Southwest already has several daily nonstops out of MDW to LGA and EWR). Southwest also has nonstop service from DEN, DAL, HOU, MCI, STL, and MKE to most of the East Coast destinations that are served nonstop out of CVG on Delta. Most of those flying from DEN, DFW/DAL, IAH/HOU, MCI, STL, ORD/MDW, or MKE to the East Coast aren't going to be connecting through CVG since Southwest has nonstop service from these cities to most of the East Coast destinations that Delta serves nonstop out of CVG, since connections can be made from these cities to East Coast destinations through Delta's DTW and ATL hubs, since AA also has hubs at DFW and ORD, since UA also has hubs at DEN, IAH, and ORD, and since connections can be made from these cities to East Coast destinations on airlines other than Delta through airports other than CVG.
Midwestindy wrote:Just because there is nonstop service, doesn't mean everyone will take it
Lots of connections were still popular through CVG in 2016
MKE-CVG-CLT, CVG was the most popular connection behind ORD, DTW, and ATL
MKE-CVG-XNA, CVG was the most popular connection behind ORD, MSP, and DFW
CVG was also a common connection if you were flying MKE-BNA, or if you were flying into or out of XNA, MEM, or PIT.
cvgComair wrote:Amazon will be adding service from CVG to PVD, nice to see a new destination, hopefully they continue to roll out new cities!
