wn676
Re: Phoenix Arizona Aviation Thread Part 18
Wed Jan 18, 2017 2:07 pm
cathay747 wrote:
An interesting thought came up the other day while talking about the new BA 3x weekly 2nd flight with a fellow avgeek friend...directly related to an earlier comment about what a sight it would be to see TWO BA 744's here @ PHX at the same time...if the new flight, which is earlier, should have a delay and is still here when the "regular" flight comes in...won't this create a parking problem? Can two 744's be accommodated on that pier simultaneously?
Yes, you can park two 747s simultaneously at B23 and B25. It's rare but it has happened before with BA when an aircraft goes tech and has to RON. Both gates are Group V capable so you can park most heavies side-by-side without many issues.
Tiny, unreadable text leaves ample room for interpretation.
Vctony
Wed Jan 18, 2017 3:11 pm
chrisair wrote:
This thought came to me when I left the other day: what is WN going to do with C12 after all the 300s are out of the fleet? There's a giant sign on it that says "NO 700."
alasizon wrote:
FWIW, the rumors were a 6AM (5AM Summer) departure with like a 3-4PM return catering to PHX based business passengers for SFO, SJC and SMF.
Bleh. 5a is a brutal time for a flight. The 6a ones are hard enough on me when I have to work a full day when I land.
C12 looks like it has a "fixed" jetway like C11 and C1 (although both C11 and C1 can accommodate the 700s). I'm curious if they need to re stripe the ramp or if they can get a new non "fixed" jetway to make the 700s work on it.
alasizon
Wed Jan 18, 2017 6:27 pm
I believe the issue with C12 is the wingspan and surrounding area. I'm not sure what their plan is.
Manager on Duty & Tower Planner
alasizon
Wed Jan 18, 2017 6:38 pm
Also has happened a good number of times when LAS closes due to WX and that flight diverts to PHX.
cathay747
Thu Jan 19, 2017 12:44 am
thanks guys!
Try a Little VC-10derness
Maverick623
Thu Jan 19, 2017 5:32 am
One of the incidents that lead to an alternate taxi lane was a 777 divert to B23 while the 747 was at B25. Usual widebody push was to the zipper line, but the driver push/pulling the 777 cut the turn short and aimed for the regular Quebec line. The 777 wing passed over the parked 747 wingtip, cleared it by maybe 3 feet. Had the 747 not been full of fuel they would've hit.
Edit: found a (kinda blurry) picture.
http://imgur.com/a/kaJJ2
"PHX is Phoenix, PDX is the other city" -777Way
wn676
Thu Jan 19, 2017 5:32 pm
I remember that night too. The way the Quebec line and tail limit line were originally striped, there was never supposed to be anything larger than a Group III on that taxi line. In that instance with the 777, they should have pushed onto Romeo.
910A
Thu Jan 19, 2017 7:30 pm
First WestJet flight is due to land at around 1:30pm at IWA. It's a 738 in the Frozen livery.
atcsundevil
Thu Jan 19, 2017 10:18 pm
The airport is doing a Facebook live stream right now.
INFINITI329
Mon Jan 23, 2017 5:48 am
allegiantflyer wrote:
Who handles VX when they are in town?
Vctony
Mon Jan 23, 2017 6:03 am
My uneducated guess would be AS.
INFINITI329
Mon Jan 23, 2017 6:09 am
I doubt it at this stage in the merger, its probably to early for that
alasizon
Mon Jan 23, 2017 6:17 am
I believe it was Swissport that handled them.
hz747300
Mon Jan 23, 2017 7:06 am
Weather in SoCal causing these diversions? Somebody should tell Albert Hammond he needs to rewrite the lyrics then. Pretty cool, hope some spotters were able to avoid the skaters on the top level of the parking garage and got some pictures.
Perhaps this will show Redwood it is not the end of the world if they fly to Phoenix. They can even call it Scottsdale if they must.
Keep on truckin'...
wn676
Mon Jan 23, 2017 11:18 am
With up to 4 VX aircraft on the ground at the same time, it would make sense that Swissport handled them, especially if it was just a gas-and-go situation. I'm not sure McGee or IAS could make that happen with the resources they have here.
Sometimes it depends on the nature of the diversion. Years ago there was a VX diversion that was handled by US, I believe due in part to them needing to replace medical equipment. We parked it at A13.
alasizon
Tue Jan 24, 2017 7:55 am
Also McGee probably doesn't have the resources or training to handle Airbus aircraft. I know we had a OO SJD-SLC flight that diverted to PHX due to MX. Since the DGS employees aren't qualified by Customs or trained to handle INTL flights, we parked it at B24 and we handled everything other than the pushback of the aircraft after it was cleaned. It all depends on the nature of the diversion and if the station isn't routinely planned as a diversion point, its usually worked out on an ad-hoc basis.
Vctony
Mon Feb 06, 2017 3:41 pm
PHX put together a nice tribute video to WN that shows some nice artifacts of WN (and PHX history) for WN's 35 year anniversary at the airport:
https://www.youtube.com/watch?v=gel8Otv ... e=youtu.be
wn676
Tue Feb 07, 2017 10:28 am
There is an RFQ out for a CMAR for SkyTrain Phase 2. In the document they show the latest iteration of the alignment, including the new West GTC between 24th St. and Copperhead Dr., and the location of the future crossfield twys U/V (the guideway will pass underneath like at twys S/T).
Also, since we discuss it a lot and I can never post anything, the final T3S layout is also shown here:
https://www.phoenix.gov/financesite/Sol ... %20RFQ.pdf
Note that the West GTC will require the demolition of both the existing COP Facilities building and bus maintenance facility; presumably this would be the end of the airport circulator and rental car buses.
alasizon
Tue Feb 07, 2017 5:33 pm
The airport circulator is already gone, its just the rental car buses now. There will still have to be a bus depot somewhere that holds 5-6 buses as that is always what is used to transport folks after an aircraft ends up disabled somewhere or any time the T4 walkways are shut down and pax can't get from concourse to concourse. Although if they are rarely used, MX could always be contracted out to the Valley Metro folks or someone else.
Realistically, they could also add an airport hotel connected at the rental car station (utilizing the unused land on the front side of the rental car center). I remember there were plans for one near where T2 sits today but I don't believe that included a Sky Train connection.
chrisair
Wed Feb 08, 2017 7:43 am
Anyone know why the AA 757s seem to get parked on the west side of the airport now? I've seen them parked over there at South Cargo and on the north side by the executive terminal the last few weeks.
I believe the busses are (or were) operated by Veolia? They run some of the busses for Valley Metro as well. I'm sure they could do the maintenance at one of their other facilities.
alasizon
Thu Feb 09, 2017 4:21 am
We simply have too many right now. There are I believe 2 spares in PHX right now plus two of the typical 757 gates (A13/14) are OOS for ASR work. The 757 utilization is very low right now. The other day we had two parked in the West Hold Bay and two or three more parked over at East Cargo. We have also been RONing one at B28 almost daily now after it comes in from CUN due to gate availability.
I believe you are right on the Veolia piece. I forgot they operated the ones at the airport as well.
Vctony
Thu Feb 09, 2017 5:00 am
I wondered about those 757s as well. Thanks for the answer.
Actually both Veolia (now Transdev) and First Transit operate buses for Valley Metro.
There's a First Transit bus depot at 52nd St. and Rio Salado Parkway that could easily handle buses for Sky Harbor if needed (of course Phoenix would have to directly contract with First Transit and the City of Tempe for use of this facility (as I believe it's owned by the City of Tempe and contracted to Valley Metro).
Veolia is actually now called Transdev and the City of Phoenix owned garage (which is contracted with Transdev) is at 19th Ave. and Lower Buckeye Rd.
airzona11
Thu Feb 09, 2017 3:32 pm
Last night around 11 I counted 8+ tails on the west end of the North runway. Seemed like mostly 757s, but other types as well. That was interesting, had never see that. Thought there were cancellations or something.
Vctony
Thu Feb 09, 2017 3:40 pm
There actually were a decent amount of cancellations to flights to the East coast.
AA1512 to DCA, AA2026 to PHL, and AA1774 to EWR were all cancelled last night.
airzona11
Thu Feb 09, 2017 5:07 pm
That makes sense. Thank you for the information.
travaz
Fri Feb 10, 2017 1:52 am
Realistically, they could also add an airport hotel connected at the rental car station (utilizing the unused land on the front side of the rental car center). I remember there were plans for one near where T2 sits today but I don't believe that included a Sky Train connection.[/quote]
I was involved with the Airport Shuttle operation from 2000 to 2007, I am currently involved with Valley Metro. We often provide "a Bus Bridge" when something goes down on light rail. This could be provided to the Airport on pretty short notice. The big difference was we were badged by the Airport and would actually enter the ramp and could be used incase of an emergency on the runway. It could be done however.
chrisair
Fri Feb 10, 2017 8:51 am
I know it's a moot point, but why on earth did those shuttles run back to back to back to back from East Economy, sometimes 30 seconds apart, then nothing showed up for 20, or 30 minutes(!)?
I loved getting to know some of the drivers, but that was absolutely maddening. That and the shuttles that looked like busses during the fall of Saigon at 6a on Mondays. It was really tough to plan for (thank god for Uber--I've parked at PHX 3 times since Feb 2016, and flown more than 150 round trips).
travaz
Sat Feb 11, 2017 6:38 am
If you remember that was a time where there was a lot of construction and traffic. Sometimes the construction company would mess up and close all routes out of T4 going west or the traffic from all the rental car shuttles, off airport parking vans would absolutely grid lock the airport. I remember one Sunday night at 9 PM where they closed all the roads east bound from T4. It was a case of the left hand not telling the right hand what was up. I remember that traffic backed up onto I 10 to where DPS had to get involved. We did run on a schedule that was about 5 min apart. Sometimes things just fell apart. It really was a fun and challenging job sometimes. I carried a digital scanner with me and while I drove I listened to OP's, tower and other freq's. It was amazing how many things went on in a busy airport. In fact it was an AWA pilot that told me about this site.
Vctony
Mon Feb 13, 2017 6:18 am
I posted this on the most recent OAG thread, but I feel it is a relevant discussion here as well.
With NK ending their PHX - DEN service in May. I have the following thoughts.
NK's strategy in PHX hasn't really made a lot of sense to me.
PHX - DEN currently sees AA, F9, UA, and WN service in addition to NK. In May here are the following frequencies / pricing on this route (as of a search tonight 2/12/17):
AA: 4x (lowest priced fares from $57 - $188 one way depending on the day of the week)
F9: 2x (lowest priced fares from $50 - $128 one way depending on the day of the week)
UA: 6x (lowest priced fares from $43 - $129 one way depending on the day of the week)
WN: 10x (lowest priced fares from $43 - $83 one way depending on the day of the week)
A 1x daily city pair on NK where 4 other carriers combined have 22x daily flights is just not going to cut it, especially when it's not a high fare route to begin with.
I don't really understand NK's strategy for PHX. Looking at NK's other routes out of PHX, they fly PHX - DFW and seasonally PHX - ORD and MSP. They also formerly flew PHX - LAX but that route was cancelled in September with multiple AA, DL, UA, and WN flights and relatively low fares.
Every single one of NK's routes (and the LAX former route) has a minimum of 2 other competitors and high frequencies. PHX - DFW has almost a dozen AA flights to DFW and multiple WN flights to DAL. PHX - ORD has almost a dozen AA flights, multiple UA flights, a F9 flight and multiple WN flights to MDW. PHX - MSP has multiple AA, DL, SY, and WN flights.
The hassle of flying NK at low frequencies for barely any savings over the competitors who offer multiple frequencies, wifi, carry on baggage at no additional charge, and much more useful frequent flyer programs just doesn't seem worth it.
F9 seems to make PHX work as they've found some unserved or underserved markets. F9 is the only carrier flying PHX - CLE, COS, and CVG. In addition, F9's other markets out of PHX are traditionally higher fare markets, markets less susceptible to competition by automobile, markets with only one other competitor, or DEN and ORD which make more sense as F9 routes due to F9's stronger presence in PHX.
Of the ULCC carriers in the PHX area. G4 has found a niche of serving secondary markets from a secondary airport (AZA). F9 has found a niche of serving markets with decent O/D numbers but are either not served or under served by other carriers out of the main airport (PHX). NK hasn't found a niche and seems to have simply decided to add flights to the markets that have the most daily non stops from PHX with the hopes that it would work. LAX didn't. DEN didn't.
Spotter787
Wed Feb 15, 2017 10:52 pm
[quote="wn676"]There is an RFQ out for a CMAR for SkyTrain Phase 2.
Thank you for posting this. It's very interesting. Looks like SkyTrain will be an airport version of Mr. Toad's Wild Ride with the underground and raised sections shown in the route diagram. <If I understand correctly.>
910A
Thu Feb 16, 2017 1:34 am
Phoenix Sky Harbor International Airport splashes a string of 2016 accomplishments across its website: Terminal 3 makeover, No. 1 ranking from a top frequent-flier website and 20 years of British Airways service.
"What a year for Sky Harbor,'' it says.
But last year wasn't great for the city-owned airport by one key measure: passenger traffic.
Figures released Monday show that the number of passengers traveling through Sky Harbor fell 1.4 percent in 2016, the first drop since 2013 and the biggest decline since 2009.
http://www.azcentral.com/story/travel/a ... /97740874/
Speaking of T3, I had my first experience in that terminal yesterday. Holy cow, that's quite a hike from gate 17 to the baggage claim, then back to the SkyTrain..at least one get's their leg moving. :veryhappy:
Vctony
Fri Feb 17, 2017 7:02 am
Looks like a F9 and WN jet clipped wings.
http://www.azcentral.com/story/news/loc ... /98030232/
blackbox67
Fri Feb 17, 2017 7:27 am
looks like it occurs on the northern side. A320 appeared pushing back too close to twy
https://twitter.com/JacdecNew/status/832487530075336709
futureatp
Fri Feb 17, 2017 6:07 pm
Who handles the frontier's ramp in Phoenix?
wn676
Fri Feb 17, 2017 7:37 pm
Sounds like F9 was cleared to push off of Gate 25 behind WN. There's about 3 minutes between that clearance and when WN finally came taxiing down C. Flights were F9 756 to DEN and WN 4182 arriving from OKC.
F9 receives push clearance at 23:54, and the aircraft collide around 26:50:
http://archive-server.liveatc.net/kphx/ ... -0230Z.mp3
wn676
Fri Feb 17, 2017 7:39 pm
I believe it's Simplicity USA.
910A
Mon Feb 20, 2017 6:41 pm
Interesting day at IWA..Going into my Physician office this morning which is located just north of runway, I notice a C-Series plane flying overhead. After the appointment I went over to the airport and a Bombardier C-Series unpainted was doing touch and go's. It's a super quiet plane. An AN-124 was seen at the eastern edge with it's loading door's open. Finally since when did SwiftAir get a new livery? A 27 year old former US 734 (N438US) was sitting near the ICE facility sporting a sharp looking livery.
MO11
Mon Feb 20, 2017 7:27 pm
October. N438US is Swift's latest; entered service in the last week of January.
910A
Mon Feb 20, 2017 8:52 pm
Thank you for the info.
Osubuckeyes
Tue Feb 21, 2017 2:43 pm
To me NK has basically been throwing darts in PHX. I am a bit surprised that they are ending DEN as I believe that was one of their first markets in PHX, but it is a route with heavy competition. I am still surprised they haven't given PHX-LAS a go, seems to me that would be tailor made for them.
Additionally F9 has been a mixed bag as well. Recently they have expanded a bit more, but they've been in and out of PHX-SLC, and dropped SFO, while CLE was seasonal last year (seems that it will be retained this year). WN also flys PHX-CLE 2x during spring peak, and 1x year round. Overall my observation in PHX is that AA and WN are more than willing to match or come close to F9 and NK fares especially on shorter routes, and the value proposition to the reasonably educated shopper is undoubtedly with WN and to a slightly lessor extent AA.
Vctony
Thu Feb 23, 2017 3:27 pm
New WN schedule is out.
PHX is down another -9 in the new peak schedule.
PHX peaks at 187 daily departures in the April schedule and is down to 154 (a low point) in September.
Notable changes are as follows:
HOU -1
IND -1
BNA -1
OMA -1
SMF -1
SAT -1
SJC -1
SEA -1
STL -1
TPA -1
TUL -1
On the plus side:
OAK +1
SAN +1
Vctony
Thu Feb 23, 2017 4:25 pm
HOU -1
IND -1
BNA -1
OMA -1
SMF -1
SAT -1
SJC -1
SEA -1
STL -1
TPA -1
TUL -1
On the plus side:
OAK +1
SAN +1
This schedule is the Sunday Schedule.
The peak Weekday schedule is at 171 departures.
Currently WN runs the peak schedule on Sundays which is what the confusion was in my numbers.
4holer
Tue Feb 28, 2017 5:16 pm
The visitingphx site says that the old white 727 has flown to MZJ. Sad to see it go, but glad it got to have one last flight. I'd been afraid it would be scrapped on site like the old Honeywell B720.
Ghosts appear and fade away.....................
INFINITI329
Wed Mar 01, 2017 6:17 am
Does anyone know if the current route from the gates to baggage claim will be same once the T3 renovations are complete?.That's a very lengthy walk from the gates to baggage claim hopefully another route is in the plans.
wn676
Wed Mar 01, 2017 4:18 pm
It's a result of having phased construction. There will eventually be an escalator bank that will take you through the checkpoint level directly to baggage claim.
INFINITI329
Wed Mar 01, 2017 5:21 pm
I just went through the rendering and virtual tour and I see what you're talking about. However, I feel two escalators will not be enough especially during peak periods. That has the ability to be a major bottleneck area
paulsaz
Wed Mar 01, 2017 5:31 pm
AA had a 767 drop in yesterday as a sub ORD-PHX-DFW. Didn't get a chance to see it, we don't get a lot of AA widebody love in PHX, other than the A330.
wn676
Wed Mar 01, 2017 6:02 pm
Each escalator can move about 100 people per minute, so that should be more than sufficient. Keep in mind T4 only has 4 down escalators to the baggage claim area for 7 concourses too.
4holer
Wed Mar 01, 2017 6:09 pm
I wonder if the new ownership of the website is scrambling to register the domain name escalators.net?
