SpaceshipDC10
Search function and "your posts" not working
Sat Sep 29, 2018 8:53 am
This week I've posted three separate threads, all regarding Air Transat, they are visible in their respective forums but they don't appear in that menu. I link'em below.
viewtopic.php?f=3&t=1404799
viewtopic.php?f=3&t=1404959
viewtopic.php?f=4&t=1404793
Reason: Threads merged
dcajet
Re: Threads not appearing in "Your posts" menu
Mon Oct 01, 2018 12:08 am
Same case here and I can't find them any longer using the search either. Have sent a message to moderators yesterday afternoon (US PDT).
Max Q
Mon Oct 01, 2018 1:48 am
I’m having the same issue
deltadudejg
Search function not working
Mon Oct 01, 2018 2:18 am
For some reason I cannot use the Search This Forum bar. It's been out for 5 days for me where it only shows results up to the 25th. Ive tried on multiple computers/devices.
Aviation Enthusiast working in Airport Operations
qf789
Re: Search function not working
Mon Oct 01, 2018 12:31 pm
The issue has been reported to out community manager which will be past on to the developers of the site to fix
Forum Moderator
qf789
Mon Oct 01, 2018 12:33 pm
The issue has been reported to out community manager which will be passed on to the developers of the site to fix
Forum Moderator
PanAm_DC10
Community Manager
Mon Oct 01, 2018 9:46 pm
Hi All
I have forwarded this issue to the developers of the site and am awaiting their response
Paul
Ask the impossible to achieve the best possible
PanAm_DC10
Community Manager
Mon Oct 01, 2018 11:07 pm
Hi All
I have forwarded this issue to the developers of the site and am awaiting their response. No timeline on when they will be able to look into it.
Paul
uconn99
Mon Oct 01, 2018 11:15 pm
Same here, only see results up until the 25th. In the past it worked on and off but then worked fine for probably over a year with no issues. I use the search function quite a bit, it would be great to have it working again.
deltadudejg
Tue Oct 02, 2018 1:59 am
Thank you all! I appreciate the quick respone!
dutchspotter1
Tue Oct 02, 2018 7:37 am
You'd better appreciate a quick fix, but based on past experiences that is not likely to happen.
NO URLS in signature
stl07
Wed Oct 03, 2018 3:22 am
I'm not seeing any search results now...
I'd rather be in FLYover country than layover county
stl07
Wed Oct 03, 2018 3:23 am
If that is the case then I will stop using this site since finding the info I need on Wiki will be faster
SpaceshipDC10
Wed Oct 03, 2018 7:56 am
Don't know whether it's because they are working on it or not, but right now in the same menu I get the following message: "No suitable matches were found."
747classic
Wed Oct 03, 2018 8:03 am
I have the same issue. This feature is very important, because you are now practically unable to look for answers on your replies.
Operating a twin over the ocean, you're always one engine failure from a total emergency.
Max Q
Wed Oct 03, 2018 8:06 am
Yes, I have the same issue now
SomebodyInTLS
Wed Oct 03, 2018 1:32 pm
Me too...
"As with most things related to aircraft design, it's all about the trade-offs and much more nuanced than A.net likes to make out."
flymia
Wed Oct 03, 2018 4:03 pm
The search function does not work at all.
It also find it odd that I can't figure out a way to search for threads I started.
Indy
Thu Oct 04, 2018 1:00 pm
It actually should be a very easy fix. The search index likely needs to be rebuilt. There is a function for this in the PHPBB admin menu. I know the search feature functions because I was able to pull up one result. It just tells me the word table has been wiped out and needs to be rebuilt.
Indy = Indianapolis and not Independence Air
VertScopeJeff
General Manager
Thu Oct 04, 2018 3:27 pm
Heya all,
We are working on a fix for it right now, standby for updates.
Jeff M
VertScopeJeff
General Manager
Thu Oct 04, 2018 3:42 pm
We are working on search now, the fix might sort this issue also.
Thread on it here: viewtopic.php?f=12&t=1405123
Jeff M
VertScopeJeff
General Manager
Thu Oct 04, 2018 4:08 pm
I believe search has now been resolved.
Jeff M
dcajet
Thu Oct 04, 2018 4:17 pm
Jeff M
Hello - All of my postings since last week are still not appearing either under the general search or the search under "my posts". Just tried it out for a few times, changing browsers, etc.
L.
SomebodyInTLS
Thu Oct 04, 2018 4:35 pm
My "Your posts" started being repopulated this afternoon...
Edit: I mention this since I don't know if it's related or not - often I can't open the hamburger menu at the top left to select "your posts"... it just turns into a cross (to close) when I put the mouse there. I found a workaround is to click the notifications icon first, then from there I can open the hamburger menu.
I don't know if this is a change on your site (since it started about the same time as the broken search / "your posts" thing) or because my browser also updated around then (Vivaldi, based on Chromium, updated to the Chromium 70 engine).
VertScopeJeff
General Manager
Thu Oct 04, 2018 5:07 pm
Jeff M
L.
Can you link me to a few of those threads here so I can have them look into it.
Jeff M
dcajet
Thu Oct 04, 2018 5:36 pm
Jeff M
L.
Jeff M
Hi Jeff - thanks for reaching out. Here's a few threads I have been active in the last 24 hours and won't show up in the "my posts".
viewtopic.php?f=3&t=1403601
viewtopic.php?f=3&t=1405343
Luis
VertScopeJeff
General Manager
Thu Oct 04, 2018 6:05 pm
L.
Jeff M
Luis
Thanks, anybody else having this issue?
We will look into it.
Jeff M
atcsundevil
Thu Oct 04, 2018 6:56 pm
Jeff M
Luis
Jeff M
It seems like everyone is having the same issue. My last searchable post was on 9/25, but I've posted almost daily/multiple times daily since then. It seems that the search function hasn't worked properly since the cloud transition a month or so ago.
SpaceshipDC10
Thu Oct 04, 2018 7:04 pm
Now it's back to how it was when I started this thread.
dcajet
Thu Oct 04, 2018 7:36 pm
Luis
Jeff M
It appears that since two hours ago, two posts I entered this AM (US PDT) are now showing up under "my posts", but not the ones between a few days ago and earlier today.
VertScopeJeff
General Manager
Thu Oct 04, 2018 7:39 pm
Thanks guys, lets give it 24 hours or so in case it is a caching issue.
Paul and I will check back in.
Jeff M
dcajet
Thu Oct 04, 2018 10:38 pm
Jeff M
Jeff, one more comment. If I respond to an existing thread, the thread goes to the top of the list under "my posts", as it should. If I start a new thread (e.g: viewtopic.php?f=3&t=1405443) it does not appear at all under "my posts".
Thanks again.
Luis B.
atcsundevil
Re: Search function and "your posts" not working
Thu Oct 04, 2018 11:02 pm
FYI — I've merged the two threads since both described the same issue.
✈️ atcsundevil
SpaceshipDC10
Fri Oct 05, 2018 1:02 pm
History of my posts is back to normal.
VertScopeJeff
General Manager
Fri Oct 05, 2018 2:13 pm
Cool good news they did a Re-Sync which seems to have solved the issue.
Jeff M
dcajet
Fri Oct 05, 2018 3:00 pm
Jeff M
It has. Appreciate the attention to this issue, Jeff.
Luis B.
Max Q
Sat Oct 06, 2018 3:22 am
It was fixed but at 2320 EST the problem has returned
‘Search found 0 matches’
748iDEN
Sat Oct 06, 2018 5:00 am
At 10:43PM MDT the search function stopped working. Currently displaying 0 results regardless of what is put in the search engine. Hopefully its an easy fix!
dcajet
Sat Oct 06, 2018 4:23 pm
Jeff M
It did the trick... for a bit. Search function and "your posts" not working this morning.
SpaceshipDC10
Sat Oct 06, 2018 6:39 pm
Now I'm back to "No suitable matches were found."
PanAm_DC10
Community Manager
Sun Oct 07, 2018 3:34 am
Hi All
We got hold of the developers and they looked into it and the issue appears to be resolved with search working and your posts displaying. Please let us know if you encounter any further issues related to this.
Paul
dcajet
Sun Oct 07, 2018 3:20 pm
PanAm_DC10 wrote:
Hi All
Paul
It is - Thanks.
L
SpaceshipDC10
Sun Oct 14, 2018 7:49 pm
Here we go again. Two threads, including one I started, don't show up in the list of my posts.
PanAm_DC10
Community Manager
Mon Oct 15, 2018 1:03 am
Hi the site is having some issues at the moment and I will report to the developers. It's working sometimes and sometimes not so it's sporadic at the best. We'll get onto Jeff again so it can be looked into.
Paul
SpaceshipDC10
Tue Oct 16, 2018 8:42 am
Paul
Hi, everything seems to be back to normal since yesterday.
747classic
Thu Nov 01, 2018 7:06 am
"Your posts" function not working.
Following message displayed : Sorry, search could not be performed. More information about this failure has been logged in the error log.
qf789
Thu Nov 01, 2018 12:08 pm
Yes I am getting the same and have reported it so it can be looked at
Forum Moderator
qf789
Fri Nov 02, 2018 2:14 am
The search your posts function is now working again
Forum Moderator
iflykpdx
Fri Nov 16, 2018 4:52 pm
The search function is working, but I am positive that not all posts are being correctly indexed. I have done searches on terms that I had literally just seen posts including the keyword for, only for them not to show up in the results.
Airport Management - UND
