Airstud
ODBC Driver architecture mismatch thread
Fri May 19, 2017 8:12 am
We are long overdue for a thread on how to handle a SQL error IM014 that arises when Microsoft's ODBC Driver Manager reports that a specified DSN contains an architecture mismatch between the driver and the application.
(I mean we were ALL thinking it...)
See, I have set up a little MySQL database (I'm running MySQL Server 5.7) on my HP EliteBook 6930p laptop which runs Windows 7 Home Premium , Service Pack 1, 64 bit.
I want I should be able to access this database from within OpenOffice.org (fight the power of Microsoft! :grin:) so I have the MySQL ODBC connector installed and I used the Data Sources ODBC administrator tool in Control Panel to create a User DSN pointing to the MySQL database I wanted, that all went well.
Then I followed the instructions at https://wiki.openoffice.org/wiki/Connec ... on_Windows
for creating new "Base" file that connects to an existing database, and blame it, it was going so well... Base even found the database I wanted and said "Connection successful." But when it came time to finalize user authentication (which worked fine, with the exact same user credentials, when I was setting up the User DSN in Control Panel), I got that "specified DSN contains an architecture mismatch between the Driver and the Application." :boggled:
Googling has taken me to a half dozen websites that all say this problem arises when you use a 32-bit ODBC driver to connect to a 64-bit system. So from my Start menu I did a search for any files that have "odbc" in their names; it turned up three results
mysql-connector-odbc-5.1.13-win64 (1)
mysql-connector-odbc-5.3.7-win64
Also I went back to the ODBC Data Sources tool and noodled around for "Details" or "Advanced" settings where you could specify 32-bitness or 64-bitness; but found no such options.
So how is a 32-bit ODBC driver anywhere in the picture here? :boggled:
Anyway... much appreciatitude if anyone can shed some light on this.
And, as always:
:boggled:
Pancakes are delicious.
vrbarreto
Re: ODBC Driver architecture mismatch thread
Fri May 19, 2017 9:30 am
Have you tried turning it off and back on again? :D
Airstud
Fri May 19, 2017 9:45 am
Thanks Roy.
vrbarreto
Fri May 19, 2017 10:18 am
Airstud wrote:
Thanks Roy.
Pleasure.
There might be something in here that helps you
http://www.itgo.me/a/x50260285088327517 ... -and-appli
I understand there is no 64bit version of OpenOffice?
LibreOffice 64 bit is available
https://www.libreoffice.org/download/download/
Perhaps try that?
Users browsing this forum: Aesma, DocLightning, LMP737 and 28 guests
