kanban
US Grounds all F-35s for fuel line failure
Thu Oct 11, 2018 2:49 pm
per https://www.bbc.com/news/world-us-canada-45827795 the US military has grounded all F-35s after an analysis of the earlier crash.. the article also mentions undefined "other issues" (quotes mine because no specifics were given)
itchief
Re: US Grounds all F-35s for fuel line failure
Thu Oct 11, 2018 6:25 pm
The stand down affects more than 200 jets while an "inspection of a fuel tube" in F-35 engines takes place, according to a Pentagon spokesman. “If suspect fuel tubes are installed, the part will be removed and replaced. If known good fuel tubes are already installed, then those aircraft will be returned to flight status. Inspections are expected to be completed within the next 24 to 48 hours,” Joe DellaVedova, a spokesman for the F-35 program
Ozair
Thu Oct 11, 2018 6:54 pm
Unfortunate but standard practise when a faulty part enters the supply chain. Sounds like the part is not in a difficult place to access so shouldn't be long before the fleet is back up again. Would be interested to know what the estimate is on the number of faulty fuel tubes in the fleet.
Ozair
Re: F-35 news thread
Fri Oct 12, 2018 8:27 am
Looks like not all F-35s have been grounded as the UK are continuing to operate the Bee from QE.
Contrary to reports, all F-35 jets have not been grounded. We have paused some F-35 flying as a precautionary measure while we consider the findings of an ongoing enquiry. Flight trials from @HMSQnlz continue and the programme remains on schedule #F35 @thef35
https://mobile.twitter.com/DefenceHQ/st ... 0293050368
Nomadd
Fri Oct 12, 2018 5:23 pm
The fault that caused the problem is the easy part. The fault that allowed the defective part is harder. Somebody not only made a bad tube, they probably ignored steps or falsified documentation that should have insured such parts wouldn't make it through. This kind of crap is what makes the U.S.A.F. the worst micromanager in the universe in the first place.
checksixx
Sat Oct 13, 2018 12:31 am
The US Air Force produces exactly ZERO of ANY parts in the F-35.
Nomadd
Sat Oct 13, 2018 7:08 am
I was obviously talking about the contractor who makes it, and you're wrong in any case. The maintenance depots often fabricate low tech parts since Lockheed isn't the kind of company you can call to pull a part out of an assembly line bin. They've even started 3D printing some, which you'd know if you bothered reading the news thread.
smithbs
Sat Oct 13, 2018 4:59 pm
A risk-balanced approach to keep the QE timeline on track?
Mortyman
Sun Oct 14, 2018 1:01 pm
All Norwegian F-35 is back in the air after only half a day of inspection.
checksixx
Sun Oct 14, 2018 3:59 pm
We are talking about a faulty design in a fuel part. I was 100% correct in regards to the topic - The Air Force designed exactly ZERO of the F-35 parts. 3D printing parts is producing the part after the fact, for which they had no hand in the design or testing of such part. As far as the news goes, I'm up to date (very much)...I just don't twist what I'm discussing to meet my needs vs. what the thread is actually discussing.
