ikolkyo
Embraer KC-390 prototype off runway at Gavião Peixoto test facility
Sat May 05, 2018 9:27 pm
Embraer says that its prototype KC-390 airlifted suffered “a runway excursion” at its Gavião Peixoto test facility. Company says crew was unhurt and deplaned safely. The airport has one of the longest runways in the world (was a Space Shuttle alternate strip). No word on damage.
https://twitter.com/jonostrower/status/ ... 0984918017
Video of the aircraft.
https://www.youtube.com/watch?v=TVqFSxoDbi4
WIederling
Re: Embraer KC-390 prototype off runway at Gavião Peixoto test facility
Sun May 06, 2018 7:13 am
ikolkyo wrote:
First Aid: taping over the decals.
( doesn't look damaged at all?)
Murphy is an optimist
Sun May 06, 2018 8:49 am
They are covering
G it up to avoid bad publicity
WIederling
Sun May 06, 2018 9:13 am
zeke wrote:
They are covering
ja, sarcasm doesn't carry over all too well on occasion. :-)
reffado
Thu May 10, 2018 2:49 am
Doubt we’ll ever know what happened, but the aircraft appears to be extensively damaged. I wonder what the circumstances were, to overrun a 16,000 ft runway.
AirlineCritic
Thu May 10, 2018 7:29 am
Seemed to have run over the end of the runway, skidded sideways and hit a fence?
But why indeed run over at 16,000 ft? Late abort? But even so...
(It would seem to have some information, given that we're talking about publicly traded companies.)
bigjku
Thu May 10, 2018 3:41 pm
Particularly in that it’s a publicly traded company making an aircraft on a democratic government contact right?
edu2703
Thu May 10, 2018 3:54 pm
New images
EMBSPBR
Thu May 10, 2018 6:30 pm
There is:
Source: https://embraer.com/global/en/news#/906346-communique
"Gavião Peixoto, Brazil, May 10, 2018
Embraer informs that after an initial evaluation of the KC-390, prototype 001, which was involved in an incident on May 05, when it experienced a runway excursion while performing ground tests at Embraer's Gavião Peixoto (SP) facility, extensive damage was identified on each of the three landing gear of the aircraft, as well as damage to the structure of the fuselage. Initial analyses indicate that the aircraft and all systems behaved normally, according to the design characteristics.
The Company is evaluating the planning schedule for the continuation of certification tests, including the possibility of transferring some tests to prototype 002 and to the first series aircraft, which are already in an advanced stage of assembly. Embraer maintains its forecast for the achievement of the Final Operational Capability, object of the final military certification of the aircraft, as well as the first delivery to the Brazilian Air Force, in the fourth quarter of 2018.
The Company has already initiated the investigation to find the causes of the incident and remains at the disposal of the aeronautical authorities."
Catfry
Thu May 10, 2018 7:10 pm
edu2703 wrote:
New images
wow, that landing gear is fucked up! All wheels wrenched away, shock absorbers and struts just torn right apart. This is not the result of some ordinary hard landing, something very violent happened here.
Earlier articles posted in the thread cited designers as saying that the design is made so that the gear assembly fails first, before the larger plane structures take damage. this is sound in principle, but perhaps the threshold for failing is set too low?
mham001
Thu May 10, 2018 8:48 pm
Or, it did its job, had its intended effect and helped prevent further damage.
Catfry
Thu May 10, 2018 9:09 pm
that's very true. However what were they DOING to cause such a last ditch structural emergency response? I will be very curious to see what emerges.
Users browsing this forum: aviationaware and 9 guests
