FlightXCVI
C-5 Galaxy re-engine?
Thu Sep 14, 2017 9:39 pm
The C-5 galaxy is undoubtedly an amazing aircraft. I think that the life of these heavy lifters could be extended dramatically if we could slap some new tech on it. Imagine your grandpa getting an IPhone and a Bluetooth headset. Maybe a smart watch too. A wing upgrade would be nice as well. You could apply the same concept to the C-17.
sixtyseven
Re: C-5 Galaxy re-engine?
Thu Sep 14, 2017 11:50 pm
they're flying the b-52 around with the same pipes and it's going to be flying forever. I don't think the military cares too much about the operating cost of doing anything. What gets them into trouble is when they have to dip into the budget for these projects. Rewinging "Fred" would cost enough to rebuild Barbuda
flyingclrs727
Thu Sep 14, 2017 11:51 pm
Already happened. All C-5B's, and C's and a handful of A's were converted to C-5M's with GE CF6-80C2 engines. The last C-5A still flying that won't be converted flew to the boneyard a few days ago.
http://www.lockheedmartin.com/us/aerona ... o/c5m.html
sixtyseven
Thu Sep 14, 2017 11:54 pm
I think the M mod extended its service life til into the 2040s, no?
flyingclrs727
Fri Sep 15, 2017 12:00 am
All the original C-5's now known as A and C models had new wings installed in the 80's. All the B models were originally built with the updated wings. Why would the M's need new wings?
KICT
Fri Sep 15, 2017 12:04 am
Since when is the C-5 a civilian aircraft?
Andre3K
Fri Sep 15, 2017 12:49 am
To be more precise, the C-5M mod's are not totally done, there is at least one, possibly two still being worked on here. Should be totally finished by March.
flyingclrs727
Fri Sep 15, 2017 12:55 am
But all the ones that aren't being upgraded have been retired. With the retirement of the TF-39 engines, there's no way to fly any C-5A's to Georgia to go through the RERP process.
Andre3K
Fri Sep 15, 2017 1:00 am
I didn't say we are getting new ones. It takes months and months just to do the stuff inside the hanger and months and months to then do the stuff on the flightline. It's not like building a 737 where you move to a new station every 12 hours.
TW870
Fri Sep 15, 2017 2:05 am
Thanks so much for that update. This is a sad day. The TF-39 has got to be the coolest, most dramatic sounding turbofan that has ever operated. In every phase of flight it makes a different, highly memorable sound. I see the C-5Ms fly, and they just are not the same because they sound like any run of the mill CF6 powered bird. I always though the mystique of the C-5 was both its massive size and its crazy, screaming whining sound. Now that is history.
You have to admire the how long the TF-39 lasted though! Talk about a high fuel burn, high maintenance machine. It seriously makes the JT9D-3A look modern.
glideslope
Fri Sep 15, 2017 2:08 pm
Every 11hrs in 2019. ;)
flyingclrs727
Sat Sep 16, 2017 5:45 pm
I found the sound of the TF-39 quite grating. It sounded as if someone left some loose screws in them. It was a wonder to me that an engine in proper working order could make such sounds.
ssteve
Mon Sep 18, 2017 2:25 pm
Proper working order may be setting the bar too high.
flyingclrs727
Mon Sep 18, 2017 2:52 pm
I never could understand why the C-5B's which were built in the 1980's were delivered with TF-39's. Why couldn't the CF6-50 have been substituted for the TF-39. After all the CF6 is a derivative of the TF-39. It was also the engine used for the KC-10, so it could have had commonality with an engine already in the USAF inventory.
Users browsing this forum: No registered users and 33 guests
