ODwyerPW
AIRCRAFT Brazil - Air Force Embraer VC-99B (EMB-135BJ) ID NUMBERS REG: 2582 MSN: 145495
Thu Aug 31, 2017 5:00 am
There are many pictures of this aircraft out on the net.... Outside only... Though honestly I am very curious to see if it has the 1+1 16pax shuttle config.
What I find interesting is the fairing around the wingroot is so large compared to other ERJ-135s. Why is that?
AIRCRAFT
Brazil - Air Force
ID NUMBERS
REG: 2582
MSN: 145495
http://www.airliners.net/search?registr ... lay=detail this search yields a ton of photos showing the large fairing. Perhaps it is because this plane is based off a Legacy 600, instead of just the 135LR?
learning never stops.
battlegroup62
Re: AIRCRAFT Brazil - Air Force Embraer VC-99B (EMB-135BJ) ID NUMBERS REG: 2582 MSN: 145495
Fri Sep 01, 2017 3:51 am
I can't tell you for sure if it still has its 1+1 seating but it did originally as delivered have 17 seats until it was stored by Flight options in 2007. It also was in a collision in 2004 and was re-registered after repairs were made.The plane was originally built as an EMB-135BJ, which has the marketing designation of Legacy 600.The VC-99B is the Brazilian Air Force designation for an emb-135bj, just like the VC-25A is the designation for the 747-200 known as Air Force 1.The wing to body joint only looks like it has a huge fairing, it actually a conformal fuel tank with the front roughly 5 feet being a fairing housing the a/c packs and ducting, that is why it has that really odd center belly fairing with red beacon as well. Under that is a massive belly skid to minimize fuel tank damage in the event of a belly landing. The Legacy series very much has the fuselage of an emb 135 with a forward fuel tank as well as a tank in the cargo bay allowing an additional 1000 gallons of fuel as well as winglets, strakes and engines off the 145xr among other things.
We have to keep planes airworthy. That doesn't mean they have to fly.
Users browsing this forum: rheinwaldner and 12 guests
