Mortyman
Pictures of testing of braking parachute pod: The F-35A
Sat Jun 10, 2017 8:32 am
Pictures of testing of braking parachute pod: The F-35A that will be used by the Royal Norwegian Air force will have braking parachutes installed in a pod between the tail fins. Here are pictures of a test plane performing tests with the pod and parachute. Not sure if Norway will have the pod permenantly installed or only if needed. The pod can apparently be removed on and off.:
http://nettsteder.regjeringen.no/kampfl ... mseskjerm/
JetBuddy
Re: Pictures of testing of braking parachute pod: The F-35A
Sat Jun 10, 2017 2:58 pm
Great pictures! I wonder if the pod will affect the stealth of the aircraft much, or if at all. Probably a little bit of drag.
Mortyman
Sun Jun 11, 2017 11:18 am
it has been designed not to iterfeere with the stealth effect... atleast that is what is said by those who have worked on it ... We shall see
Personally I am a little dissepointed With the size of the thing. I had expected it to be smaller and not so prominent on the fuselage ...
JetBuddy
Sun Jun 11, 2017 2:18 pm
Yes, I was also surprised by the size of the pod. The F-16's pod seems much smaller. I believe the F-35 is a larger and heavier aircraft though, could be because of that.
INFINITI329
Wed Jun 14, 2017 6:30 pm
How long does it take repack the chute?
Ozair
Thu Jun 15, 2017 1:01 pm
The size is about right for the concept drawings.
compared to
The F-16 chute isn't much smaller in terms of size, it is just located at the base of the vertical stabilizer so it blends into the fuselage better.
ssteve
Thu Jun 15, 2017 4:05 pm
Why does Norway want this capability? What are the numbers on how much shorter the runway can be?
Mortyman
Thu Jun 15, 2017 11:11 pm
Because of the climate conditions in Norway and not always long enough runways across the network of smaller airports in Norway. We have had this capability on mnay of Our former fighters, including the F-5 and F-16
Calder
Fri Jun 16, 2017 12:22 pm
I would think this would also have a lot to do with braking action concerns on a contaminated runway. I have no idea with this particular aircraft has in the way of "reverse thrust" capabilities, but having lots of experience with icy runways, I'd want something aside of brakes to help slow me down upon initial touchdown.
ZaphodHarkonnen
Fri Jun 16, 2017 12:25 pm
Pretty sure the F-35 has no reverse thrust option. So yeah, icy runways mean that drag chutes are wanted.
I do wonder if the mounting points are on all F-35s or just the Norwegian ones. I'm guessing it'll only be theirs.
moo
Fri Jun 16, 2017 12:59 pm
It will use the mounting points for the spin test recovery chute system, so nothing extra has to be added into the airframe, it just has to be selected during build.
JetBuddy
Fri Jun 16, 2017 1:57 pm
Does that mean they can be retrofitted? At a higher labor cost of course.
Mortyman
Fri Jun 16, 2017 4:00 pm
Actually the Norwegian ones are a bit different:
From an article in Norwegian technical Magazine:
In order to cope with the load it is to stop up the 30 tonnes of aircraft with a parachute, the rib at the back around the engine must be made in a stronger alloy than the one normally used, with more titanium,
The rib, as well as the cable up to a separate switch in front of the cockpit, are the only physical differences between Norwegian and other F-35 ( in adittion to the pod of course ) . The system retrieves power from the hydraulics of the aircraft.
Rib:
Chute switch in n F-16 to the left and the switch in an F-35 to the right:
Mortyman
Fri Jun 16, 2017 4:01 pm
Also have to remember that the F-35 is heavier than an F-16
moo
Fri Jun 16, 2017 4:53 pm
Rib:
As I said, it just has to be selected during the build - my "nothing needs to be added to the airframe" was meaning anything new and unique for this customer, the design and validation has already been done for a load bearing structure there.
Users browsing this forum: Buckeyetech, Chris8874, GalaxyFlyer, gregorygoodwin, PW100, SamYeager2016 and 42 guests
