chiki
Brake Chutes
Fri May 12, 2017 4:43 pm
Not sure if this has been discussed before
1. Why do military planes need brake chutes whilst heavier civilian airlines don't
2.It seems its most Russian planes and not many Western planes
3. Can these chutes not deploy accidentally mid-flight
Your thoughts
Slug71
Re: Brake Chutes
Fri May 12, 2017 5:17 pm
https://www.quora.com/Why-do-fighter-je ... -they-land
I'm guessing it saves on brake wear too.
And runway length probably plays a factor too.
angad84
Re: Brake Chutes
Fri May 12, 2017 5:27 pm
1. To help them stop quick/quicker. Many military runways are far smaller than commercial strips, and when you add in the fact that military aircraft are expected to operate 24/7/365, in whatever weather the universe can cook up, you want to be able to come to a halt in the given area. Also, most military airfields (well, western ones anyway) have cables at either end of the runway and hooks on their fighters, so if an overrun is inevitable, the aircraft gets stopped before becoming an expensive landscaping arrangement.
2. In countries with lots of rain/ice/snow, the wheels will lose traction before the brakes are even close to maximum stopping power, so brake chutes are not optional, since they do the bulk of the decelaration. See: Russia and many northern countries.
3. Yes, and intentionally too. I've seen Jaguars pop the chute a few feet above the runway to dump speed (and therefore lift). As far as uncommanded chute deployment is concerned, it certainly *can* happen. You can manually jettison the chute from the cockpit, but often there will not be enough time to do so before an unintended chute deployment causes a crash. As I understand it, it's very, VERY rare though.
Hope this helped.
A
mmo
Re: Brake Chutes
Fri May 12, 2017 5:40 pm
In addition, most (I hesitate to say all) high performance fighter type aircraft don't have reverse thrust available. So, the drag chute is an additional help for breaking and reduces landing roll.
chiki
Re: Brake Chutes
Fri May 12, 2017 6:09 pm
Thanks guys for the responses and link been very helpful. Really makes sense with the Russians, they make competent aircraft a
and was surprised why they just cant stop
Mortyman
Re: Brake Chutes
Sat May 13, 2017 10:35 am
Your thoughts
Brake chutes can be and has been installed on western fighterplanes as an option for many decades. But not everyone needs this. It's primarely needed for countries that operate their aircraft on shorter runways and where there is often ice and snow. Brake chutes was/is used by some countries on the Starfighter, Saab Draken, F-5 Freedom fighter, The F-4 Phantom, F-117 Nighthawk, the F-16, F-35, Eurofighter, Mirage F1, Dassault Rafale, B-52, Avro Vulcan etc
An F-16 of the Royal Norwegian Air force deploying it's chute:
The F-35A's that Norway is getting will eventually be fitted out bith a brake chute pod between the tailfinns. So far it's only Norway that has ordered this.
RetiredWeasel
Re: Brake Chutes
Sat May 13, 2017 4:38 pm
All the century series fighters and earlier fighters like the F-4 were designed to use "drag chutes" as we call them in the US military. Brake technology with composites was not as developed, brakes were not as robust (needed to save weight for munitions) and these fighters were landing at higher speeds than the previous generation. Later fighters (ala F-15) landed at slower speeds and some had lighter landing weights (f-16) so the drag chutes were not needed and the brakes benefited from the improved technology..
All the drag chutes had a max airspeed failure point. For the F-4 it was round 200 knots. If it was deployed above that speed, then the cord would either fail or the chute would become a "streamer". They were designed that way.
All these fighters could land without the chutes, but you could anticipate having hot brakes on landing even on a 10,000 ft runway.
Mortyman
Re: Brake Chutes
Sat May 13, 2017 7:08 pm
Plenty of F-16's with drag chutes as mentioned above. So drag schutes are still needed. there is a reason why Norway has asked for that option on the F-35 at a considerable expence ...
RetiredWeasel
Re: Brake Chutes
Sat May 13, 2017 7:17 pm
Yes, I was referring mainly to the USAF versions which don't use that option and avoid snow and icy runways and prefer long ones.
spudh
Re: Brake Chutes
Sun May 14, 2017 12:04 am
I'm pretty sure the Saab Viggen had thrust reversers. But then it was a bit special in a lot of ways
angad84
Re: Brake Chutes
Sun May 14, 2017 4:10 pm
The Viggen did and the Tornado still does. Both rather special in my opinion, and not just becuase of the thrust reversers.
Aesma
Re: Brake Chutes
Fri May 19, 2017 2:03 pm
Civilian aircraft using a drag chute :
chiki
Re: Brake Chutes
Tue May 23, 2017 4:58 pm
quire cool would have loved to fly one of these and felt the difference in deceleration
cmb56
Re: Brake Chutes
Wed May 24, 2017 10:20 pm
Most military combat aircraft do not have thrust reverse. I am not aware of any US fighter types that have TRs. The Tornado does, one reason it always has a dirty back end. The drag chute takes the place of TRs and helps slow down on short runways.
cmb56
Re: Brake Chutes
WKTaylor
Re: Brake Chutes
Tue May 30, 2017 6:58 pm
I addition to prior statements about brake design and efficiencies, the USAF has generally stayed away from drag-chutes in-favor of tail-hooks for all its current generation fighters. The F-4 and A-7 proved the viability of stopping using these devices. Soooo... the USAF as fielded approach and departure end 'cable-barriers': Cables suspended across runways which are engaged by the dragging tail hooks [deliberately dropped by the crew in an emergency]. The ends of the cables are typically attached to 'boat anchor chain' on each side of the runway that is aligned in the direction of travel. As the jet moves forward it picks-up/drags ever increasing lengths of chain. This typically stops most heavy fighter-sized jets in ~100-yds or less with no damage. The problem with this method is that the barrier has to be reset after every engagement.... usually no-big deal with one-off landing or takeoff incidents. The combination of much more capable brakes and the tail hook and barriers has grossly simplified/improved USAF airfield operations.
However foreign versions of USAF fighters still rely on drag-chutes to decrease stopping distances under emergency conditions [takeoff or landing] since 'cable barriers' don't exist and modifying the airfield is too expensive, impractical or out-of-character with the nature of operations at these countries. When USAF deploys to these bases [or any 'bare-bones base'], portable barriers are usually installed for safety. When they AREN'T installed, field over-runs/run-offs have occurred with a lot of damage to the fighter.
NOTE.
Obviously the 'ancient' B-52 also has a drag-chute for this purpose and still routinely deploys it to reduce braking stress/energy... and obviously is too-heavy to use the same 'cable-barrier' system as lighter fighters are able to use in emergencies. A 2016 B-52 mishap on Guam, expresses 'why' the braking and drag-chute issues are critical. The fully-loaded MA [max TOW] BUFF hit birds that cause #5-6-7 engines to roll-back... at VR. MP determined that the jet would be unable to reach bail-out altitude before asymmetric loss of control, so he elected to keep it on the runway. The combination of spoilers, flaps and max braking reduced air speed to 'max-deploy airspeed' for the drag-chute which 'streamered' due to failure of several riser cords which asymmetrically over-loaded the canopy gores. The failed riser cords where found to be materially deficient [understrength]. The combination of over-heated brakes [on fire] and departing the pavement [into loose soil] sealed the fate of the jet. It burned-up ~100-to-150-yards past the edge of the hard surface. Thankfully the whole crew evacuated the jet safely thru pre-jettisoned escape hatches.
