LAX772LR
VIDEO: C17 descends 20,000ft in less than 1min
Sat May 06, 2017 11:50 pm
Forgiveness if this has been posted before... I didn't see it using a quick search.
But this is incredible looking!
Cockpit view of a C17 descending at twice the rate of a skydiver!
https://www.youtube.com/watch?v=khBioU1qFVY
Especially that part at 0:26 with the nose pointed down to the sea! Wow! :eek: :eek:
TWA772LR
Re: VIDEO: C17 descends 20,000ft in less than 1min
Sat May 06, 2017 11:58 pm
The F15 may have the fastest (non-classified) ground to altitude record, but the C17 has the fastest altitude to ground ratio!!! :bigthumbsup:
It doesn't even look like it has the reversers open!
You know all is right is the world when the only thing people worry about is if the president had sex with a pornstar.
AA737-823
Sun May 07, 2017 3:55 am
It's a little tricky to see, but the reversers ARE indeed open.
You can make out the white vanes at the aft edge of the cowl.
I don't know how a descent like this could be made without them!
SuseJ772
Sun May 07, 2017 4:15 am
Impressive. I can't even imagine how that would feel
Currently at PIE, requesting FWA >> >>
edmaircraft
Sun May 07, 2017 4:27 am
The G forces would be immense at pullout. Stunning!
Let me up!
TWA772LR
Sun May 07, 2017 5:32 am
Saw just now after reading your post. This is why i love the C17, it is the one big plane that you actually CAN fly like a fighter.
I guess the only way to descend faster is to A) nose down 90° and full throttle, or B) just plain fall out of the sky like a brick. Either way, this is probably the only way to descend like that AND live! :biggrin:
Apprentice
Sun May 07, 2017 6:23 am
Hi:
Technical anecdot: 1980's soviet civil airplanes like IL-62M, Tu154M, did not carry a pax Supply emergency Oxygen System (like Oxygen Generatos or dedicated system.
Their Operational Specification asked for an emergency descent from FL 33000 - 35000 to around 8000 (?) where there is enough Oxygen concentration on air to maintain life.
For IL-62, procedure call for Landing Gear Extension in a level flight (to be use as aerodynamical brakes) and, when indication says: Gear Down, they start a Brutal descend to avoid pax O2 problems for long time. Once descent was initiated, first one pilot and them the other, wear O2 Mask available for crew..
Do not recall a real such situation.
“An AME, with just a Mechanic Role”, as per one of our pilots
"A NO" is a positive answer., "DON'T KNOW" is not. My Tutor (a wise man)
tommy1808
Sun May 07, 2017 7:25 am
I would assume no more than 2.5g.
Best regards
Thomas
This Singature is a safe space......
Dutchy
Sun May 07, 2017 9:09 am
Quite an impressive machine! https://www.youtube.com/watch?v=lUUU-C-7o98
RetiredWeasel
Sun May 07, 2017 3:05 pm
While very impressive for a large aircraft, fighter aircraft used the 'bonzai' maneuver frequently while ingressing into the target area. At 25,000 ft or so, roll inverted, pull the nose down to 60-70 degrees nose low, roll back upright, then adjust throttles as necessary so you don't boom anybody. Plan a 3-4g pull up so as to level off 500' feet above the ground at 500 knots. Took much less time than 58 seconds.
outbackair
Mon May 08, 2017 10:56 am
I just found this multi-cam video of C-17 tactical approach that puts the two above to shame!
https://www.youtube.com/watch?v=Yo5DprrlEwo
JetBuddy
Mon May 08, 2017 2:45 pm
Awesome video. :) Always interesting to watch the crew work like that.
Channex757
Mon May 08, 2017 2:55 pm
The Brylcreem Boys of Betty Airways love their Royal Air Force C-17s. In fact, I would venture that had the brass not got involved with the A400M the RAF would have been happy with a mix of new Hercules and a bigger C-17 fleet.
The RAF was also doing tactical approaches and landing like this with the full Medevac fitout in the main cabin with TA surgeons and nurses working constantly. Amazing people in a plane that McDonnell Douglas built like a tank.
Channex757
Mon May 08, 2017 2:58 pm
For engine nerds
https://youtu.be/Yo5DprrlEwo?t=294
Something you rarely see nowadays, thrust reversers with reverse in the hot stream. Civilian versions generally just use bypass air nowadays.
thegman
Sun May 14, 2017 8:32 pm
Not really. Thrust reversers are stowed 2000 feet above level off altitude and you make the level off as smooth as you want.
Starting the maneuver is more violent. Once those reversers are out the plane wants to slow, and fast. This requires a large pitch down change which will put you around 0 g for a few seconds. After that the g's even out to 1 and the entire plane shakes all the way down.
This video is well produced, but the approach is a very typical one that is employed a lot more than the descent with 4 thrust reversers out.
Users browsing this forum: parapente, wimdemeester and 15 guests
