GianiDC wrote:If one of the two designated AF1 planes gets maintained does this automatically ground the other plane as well? I would guess yes because they always fly together and with just one Frame you obviously can´t do that.
BroadwayLimited wrote:I thought the whole airport would be shut down for his arrival. NOT. He arrived on the North outer most runway, (not sure of the runway number), and that side of the airport was indeed shut down for his arrival. But the South side of the airport, was operating normally. Flights landing and taking off, when he both landed and took off. Again, that totally surprised me.
BroadwayLimited wrote:Finally, the tower communications between the ATL tower and AF1 were not encrypted. I honestly thought they would be.
canyonblue17 wrote:Any idea what it would take for them to have to roll out the Air Force One backup? And how fast they could get it to PBI? I am assuming it is kept on standby for this kind of situation?
Stitch wrote:You can't shut down one of the largest (in terms of traffic) airports in the nation just because a VIP is making an arrival.
litz wrote:Stitch wrote:You can't shut down one of the largest (in terms of traffic) airports in the nation just because a VIP is making an arrival.
The words "you can't" don't mean a hill of beans when POTUS is on the move and the Secret Service is involved .. if they wanted it, they'd get it.
b747400erf wrote:GianiDC wrote:If one of the two designated AF1 planes gets maintained does this automatically ground the other plane as well? I would guess yes because they always fly together and with just one Frame you obviously can´t do that.
They only fly together on foreign trips. Correct me if I am wrong someone with more knowledge than me.
petera380 wrote:Incorrect title. The aircraft in question, 747 is a VC-25. Any air force plane the President is on is call Air Force 1. I believe if he is on a Navy aircraft it's called Marine 1.
petera380 wrote:I believe if he is on a Navy aircraft it's called Marine 1.
BravoOne wrote:The likelihood of both 747's being used at for a mission is fairly remote. The fact is one of the aircraft is usually down, or in depot maintenance while the other is serviceable. Lets just say if AF One traveled to KSEA for some reason it would be backed up by one of the C32's which would position either at Fairchild AFB, or down south at McChord AFB. I'm sure there is no set in stone policy regarding how these AF One flights are backed up, but to say that the 747 is used for all flights is simply not correct.
737tanker wrote:BravoOne wrote:The likelihood of both 747's being used at for a mission is fairly remote. The fact is one of the aircraft is usually down, or in depot maintenance while the other is serviceable. Lets just say if AF One traveled to KSEA for some reason it would be backed up by one of the C32's which would position either at Fairchild AFB, or down south at McChord AFB. I'm sure there is no set in stone policy regarding how these AF One flights are backed up, but to say that the 747 is used for all flights is simply not correct.
The "spare" 747 will go as a backup to within an hour of the aircraft the President is on. For example when President Obama was at Ft Bliss (next to El Paso) I saw the other 747 was at Albuquerque NM
