• 1
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
flyingturtle
RE: Air Force One Replacement Thread
Fri Dec 25, 2015 8:46 pm
Quoting DocLightning (Reply 244):
I believe that a requirement is that it must be CONSTRUCTED in the U.S., irrespective of whether a U.S. firm is constructing it.
Quoting Stitch (Reply 237):
Can Airbus or the EU get this to the WTO? Large government contracts must be placed the open market, and the prerequisite that the plane be built on U.S. soil only serves to exclude foreign competitors. It won't affect the mission or the capabilities of Air Force 1 in any way.
David
NBGSkyGod
Fri Dec 25, 2015 9:18 pm
Quoting flyingturtle (Reply 250):
The logic behind this mentality is that if a foreign supplier disagrees with a policy of the US they could withhold critical supplies as a form of extortion.
Pilots are idiots, who at any given moment will attempt to kill themselves or others.
flyingturtle
Sat Dec 26, 2015 12:03 am
Quoting NBGSkyGod (Reply 251):
This is funny that the USA fears extortion when they have the necessary engineers and industries to rebuild foreign aircraft parts. And as AF1 is a military aircraft, you don't need the usual aircraft part documentation to begin with... and most head of states fly on Böings, Airbii, Dassaults and Embraers, and are thus dependent on the suppliers.
David
ssteve
Sat Dec 26, 2015 5:29 am
I read about the F-35 being assembled in Japan and I'm not sure I follow the logic.
scbriml
Sat Dec 26, 2015 8:18 am
If that were really the case, the US military would never buy non-US weapons systems.
kanban
Sat Dec 26, 2015 5:18 pm
Like France and the ships they were building for Russia
Stitch
Sat Dec 26, 2015 5:24 pm
I believe the actual reason is for security reasons to ensure the integrity of the airframe and to prevent the installation of surveillance devices (i.e. - the US Embassy in Moscow).
Also, does the WTO requirements apply to military applications, which this falls under? I am guessing it does not.
bikerthai
Wed Dec 30, 2015 10:55 pm
Quoting kanban (Reply 248):
Having worked on the first two, the amount of unique structure and wiring requirements would amount to a major effort
I agree that the mod effort would be extensive. My point was that for three frames, BCA will not want to invest Engineering's assets to incorporate the mod in-line. You do not get to take advantage of all of production systems like corective actions incorporation.
I believe the decision has already been made for retrofit. So what ever mod that needs to be done, it will be done by BDS and Engineering will not be done in PDM.
bt
kanban
Thu Dec 31, 2015 2:11 am
Quoting bikerthai (Reply 257):
you could be correct.... and maybe the answer is somewhere in between a full blown mod and a in-sequence variation for structural stuff.
747classic
Thu Dec 31, 2015 6:55 am
Some detailed info about the current active 747's used by the USAF :
Both VC-25A aircraft are built according the standard master drawings with basic number block R1001- R1267 for the all pax 747-200B/300 series.
Actual basic numbers used are R1251 and R1254
The customer options are listed in the variable number block RD166 and RD167 and all off standard deviations are FAA certified with several STC's.
Note : the aerial refuelling is not FAA certified.
Almost all special modifications were completed in a special hangar and took 3 years to complete.
The four 747- E4A/B aircraft are built according dedicated master drawings in the unique basic number block R1901- R1902 (PW powered) and R1904-R1905 (GE powered).
All further customer options are listed in the variable number block RB013-RB016
The aircraft are only military certified and were special built airframes, after roll-out equiped with ex EC-135J National Emergency Airborne Command Post (NEACP) interim communications equipment. The third and fourth aircraft were built with other engines (CF6-50E) and a 8 generator electrical system. The last built aircraft was a further modified E4B, with the all final equipment installed.
All aircraft were assembled at the standard FAL and system equiped by E systems (Raytheon Intelligence and Information Systems)
All aircraft were later modified to full E-4B standard
Aircraft data ( L/N, C/N, Type, Roll out, F/F, Delivery date, Basic number, Variable number, Operator) :
VC-25A
679---23824--B747-2G4B---87-04-16----87-05-16----90-08-23-----R1251------RD166----USAF
685---23825--B747-2G4B---87-07-10----87-10-29----90-12-20-----R1254------RD167----USAF
E4
202---20682--B747-E4A----73-1676----73-06-13-----73-07-16-----R1901----- RB013----USAF
204---20683--B747-E4A----73-1677----73-09-11-----73-10-03-----R1902------RB014----USAF
232---20684--B747-E4A----74-0787----74-06-06-----74-10-15-----R1904------RB015----USAF
257---20949--B747-E4B----75-0125----75-04-29-----75-08-04-----R1905------RB016----USAF
Seen all above, most probably the new Air Force One will be assembled at the standard 747-8 FAL and later modified.
Remarks :
- most of the structural modification are already engineered for the VC-25A, e.g. modified doors and "on board " stairs, aerial refuelling etc.
- most time consuming will be the integration of the -new-communication equipment
- also time consuming will be the software adaption and certification for the modified fuel and electrical systems. (or will this be a three man cockpit)
[Edited 2015-12-30 23:50:53]
Operating a twin over the ocean, you're always one engine failure from a total emergency.
Buckeyetech
Thu Dec 31, 2015 4:05 pm
Interesting is when they decommission the current VC-25s. That will be an unprecedented amount of work removing the classified components in preparation for public display. The USAF Museum will have an easier time since their restoration facility is in a restricted area on base, and a stone throws away from the actual public museum.
B-52H, C-141C, C-5A, C-17A
bikerthai
Fri Jan 01, 2016 6:05 am
Quoting 747classic (Reply 259):
The design concept may be copied, but the engineering would probably not be re-used.
For the -8 many part numbers of major components would have rolled, which would result in requiring new retrofits anyway.
Not sure if they will keep the internal part numbering system or would they genrate a new base system. That would also influence the engineering.
Manufacturing techniques have come a long way. Not sure if you want to use an old design when a newer design is better and cheaper and you can actually find someone who know how to make it
But most important would be the current availavility of a digigital frame. While I am not sure how much of the -8 has been digitized, the fact that much have been, would also mean that a new (or copied) digital design based on the existing CATIA data would reduce protential integration problems that kanban is concerned about.
Bt
747classic
Fri Jan 01, 2016 1:28 pm
All " special parts " for the VC-25A aircraft are indeed designed according the old analoque design system and have to be made digital.
In the late nineties the 744 drawings were converted into a digital format (Catia ) and the assemly process was modified.
See : http://molucad.com/media/publications/DMS-2.pdf
Also the Basic numbers and Variable numbers were using a new starting point, while the engine type indicators were deleted at the same time.
The new system was introduced from L/N 1145 , B747-409, C/N 29030, Delivered at February 25 1998.
The 747-8 is AFAIK 100% digital. (Indirect via the 744 or designed new, special for the 748)
[Edited 2016-01-01 06:23:40]
bikerthai
Sat Jan 02, 2016 2:45 am
Quoting 747classic (Reply 262):
If that is the case, then it would be most cost effective to generate new retrofit designs directly as digital data. Even if you are just copying the design. I susspect finite element modeling also have come a long way since then, you can optimize the smallest details if you want to save weight.
Bt
kanban
Sat Jan 02, 2016 4:32 am
Quoting bikerthai (Reply 263):
and sometimes they just build blank parts and back drill..
UA444
Fri Jan 08, 2016 12:55 am
Would the new AF1s be 747-8G4? Is that code still used?
KarelXWB
Fri Jan 29, 2016 10:52 pm
I just came across this news bulletin:
http://www.af.mil/News/ArticleDispla...ntract-for-next-air-force-one.aspx
The Boeing Company was awarded a contract Jan. 29 for risk reduction activities for the Presidential Aircraft Recapitalization program, which will field the next Air Force One.
This is the first contract the Air Force has awarded for this program. Additional modifications will be made to this contract in the future to purchase the commercial 747-8 aircraft, as well as to design, modify and test those aircraft to meet the presidential mission.
Joshu
Screener
Sat Jan 30, 2016 3:01 am
Did I miss where it said how many they will be ordering?
Washington-Baltimore Spotters Group
kanban
Sat Jan 30, 2016 4:06 am
Quoting Joshu (Reply 267):
the reports are design work for two airframes.. that doesn't necessarily eliminate a third unit.
MadameConcorde
Sat Jan 30, 2016 4:07 pm
Quoting MadameConcorde (Reply 19):
Reply 19, posted Sat Jun 7 2014 21:18:29 your local time (1 year 7 months 3 weeks 5 days 2 hours ago) and read 32767 times:
I would like to see a B747-8i as the new Air Force One.
It would make an awesome looking airplane!
Quoting KarelXWB (Reply 266):
I knew it!!!!
Air Force Awards Boeing Contract For Next Air Force One
January 29, 2016 Anthony Ribeiro 1 Comment 747, Air Force, Boeing, Military
WASHINGTON — The Boeing Company was awarded a contract Jan. 29 for the Presidential Aircraft Recapitalization program, which will field the next Air Force One.
-50%
read more here
http://avgeeknews.com/air-force-awar...g-contract-for-next-air-force-one/
The new Air Force One B747-8i will be a sight to behold!
A true class act!
flyDTW1992
Sat Jan 30, 2016 6:18 pm
Quoting MadameConcorde (Reply 269):
A true class act!
Just as long as they replace that awful '60s-era livery the current ones have...
Now you're flying smart
L-188
Sat Jan 30, 2016 10:08 pm
Quoting FrmrKSEngr (Reply 57):
Tubes do not like vibration, not ideal for airplane application. The reliability issues introduced by tubes would far outweigh any additional EMP benefit over the aircraft EMP shielding.
And yet over the years countless tube radio sets have survived combat in aircraft in WWII, Korea even Vietnam.
Quoting SEPilot (Reply 194):
And how many 747's were operated by US carriers has no relevance to the issue at all.
Actually it does, since there are few airframes that can be scraped for parts to service the remaining aircraft. That is where the USAF got lucky with the similarities of the KC-135 to the 707/720. Look at photos D-M in the 1980's lots of 707 frames being scrapped to provide parts to keep those KC's and E3's flying.
If you don't have the parts you either have to spend a lot of money to make them, or you can't fly the plane.
kanban
Sun Jan 31, 2016 1:23 am
Quoting flyDTW1992 (Reply 270):
and you have some designs to be considered... ?
Quoting L-188 (Reply 271):
as far as AF! goes reconditioned commercial parts are seldom used and sufficient stores of replaceable parts are maintained.. non standard and non spareable stuff of course must be made on demand.
ZaphodHarkonnen
Sun Jan 31, 2016 11:16 am
I still think the biggest threat to the new AF1 will be the US Air Force, White House, or US Congress trying to make it do too much right from the start. I hope for the US taxpayer that the leadership clearly writes down what is needed for the aircraft's IOC and then over time put in all the nice to haves.
ssteve
Sun Jan 31, 2016 4:32 pm
I'm thinking a giant screaming eagle on the front with "USA! USA!" on the rear of the fuselage. Also, the engines should be shiny gold.
DocLightning
Sun Jan 31, 2016 8:34 pm
I agree. I think the current AF-1 livery is very anachronistic and doesn't represent the U.S. well.
What do you suggest? I don't think that a white aircraft with "United States of America" and a simple flag on the tail is adequate.
-Doc Lightning-
-Carl Sagan
DocLightning
Sun Jan 31, 2016 8:37 pm
Quoting SSTeve (Reply 274):
https://fortunedotcom.files.wordpress.com/2015/07/gettyimages-163519629.jpg?quality=80&w=1024
How about this livery?
-Doc Lightning-
-Carl Sagan
Devilfish
Sun Jan 31, 2016 9:40 pm
More information here.....
http://www.flightglobal.com/news/art...ract-of-air-force-one-reca-421423/
Doubt it.....
https://www.flightglobal.com/assets/getasset.aspx?itemid=65661
http://avgeeknews.com/wp-content/uploads/2016/01/a1-800x445.jpg
Quoting DocLightning (Reply 276):
I think that would go to the Trump'eter' from Alaska.....
Oroka
Sun Jan 31, 2016 9:48 pm
lol I wonder what President Trump will do with his 752 when the USAF and American people present him with a shiny new 748?
Sooner787
Wed Feb 03, 2016 6:11 pm
Quoting Oroka (Reply 278):
The family can use it for weekends to West Palm beach.
Save the taxpayers money not using AF2 and the other smaller jets
in the Presidential air wing
Moose135
Wed Feb 03, 2016 6:56 pm
Quoting Sooner787 (Reply 279):
Save the taxpayers money not using AF2 and the other smaller jets in the Presidential air wing
I'm not sure the Secret Service (who make the rules) would go along with that.
NBGSkyGod
Wed Feb 03, 2016 10:53 pm
Why would the Vice President be going to West Palm? Did you mean the C-32 or C-40?
SEPilot
Wed Feb 10, 2016 2:17 am
I do not think the cost of parts is an issue for keeping AF1 flying, and I also do not believe that the Air Force would even consider for a moment using used parts on AF1. It is not being used on military missions like the KC135, where losses are basically expected. This is the last plane in the entire Air Force that they want to have a problem with.
Sooner787
RE: Air Force One Replacement Thread Pt2
Wed Feb 10, 2016 4:20 pm
Apologies if this has been asked already, but willl a 748I
fit inside the current VC-25 hangar at Andrews or will they
need to expand the hangar ?
Stitch
Wed Feb 10, 2016 10:46 pm
Quoting Sooner787 (Reply 1):
Apologies if this has been asked already, but willl a 748I fit inside the current VC-25 hangar at Andrews or will they need to expand the hangar ?
The hangar should be large enough, I believe.
nomadd22
Thu Feb 11, 2016 1:15 am
You could fit two of them in there.
Anon
flyDTW1992
Fri Feb 12, 2016 11:23 am
I wonder, since it's very much a derivative of the current aircraft, will it be called VC-25C, or VC-25E, etc.? A la Super Hornet, C-130J, and so forth.
ZaphodHarkonnen
Fri Feb 12, 2016 11:35 am
I'd put money on wither VC-25B as the current one's are VC-25A's; or VC-25I as it's a derivative of the B747-8I
PC12Fan
Sun Feb 14, 2016 3:22 pm
But they could have had a VC-8! Sorry, had to do it.
IMO, I think it will get it's own designation. I have nothing to base this on, it's just a guess.
Just when I think you've said the stupidest thing ever, you keep talkin'!
AviationAddict
Sun Feb 14, 2016 3:50 pm
Quoting PC12Fan (Reply 6):
Using the C-20 & C-37 as a basis I'd say it could go either way.
Taking size out of the equation the differences between the B744 and B748 are similar to the differences between the G-III and G-IV (different engines, upgrades avionics, etc.) and both Gulfstream models were given the C-20 designation.
On the other hand, the B748 is longer and has an enlarged upper deck when compared to a B744, which would make it similar to a G-V when compared to a G-IV. The G-V got a totally new designation in C-37.
I'd say it's 50/50 at this point.
Side question, who or, what group, actually makes the determination on what to designate a new aircraft?
prebennorholm
Mon Feb 15, 2016 2:39 am
Nah, I don't think the C-8 will ever make it to become a VC-8 and AF1
Photo © Richard Werno
The Brazilian Air Force has, however, produce a nice VIP version of the C-8....
Photo © Ricardo Hebmuller
.... but I'm not sure the US president will accept it without substantial upgrades. At least the First Lady might request a different seat color.
[Edited 2016-02-14 18:51:57]
7BOEING7
Mon Feb 15, 2016 4:28 am
Quoting AviationAddict (Reply 7):
Remember, we're not talking about a B744 but a B742 and the differences between that and a B748 are a little more dramatic. The Japanese got the B744 for government VIP travel.
AviationAddict
Mon Feb 15, 2016 1:56 pm
Quoting 7BOEING7 (Reply 9):
That's true, I'm not sure what I was thinking when I typed B744.
When this question was first posed I immediately guess it would end being VC-25C or some other variation of the current designation but now I'm starting to lean more towards a totally new designation. The current VC-25s will probably remain in service for at least a short period of time after the -8s come online and I suspect both the USAF and the secret service would prefer separate designations to cut down on any possible confusion - if both types are out doing missions and one has an issue I would think they'd want to know which one it is immediately and having both named VC-25s could cause problems. We're not talking fighters here, there's more at stake.
Quoting flyDTW1992 (Reply 4):
The current US designation system avoids the use of I and O for suffixes to avoid confusion with the numbers one and zero.
larshjort
Mon Feb 15, 2016 3:04 pm
The 747-400 got the C-33 designation
You've got the following cargo designations for the various 747 variants:
C-19 - 747-100
VC-25 - 747-200 hybrid
C-33 - 747-400
Following this system I sat it is a fair chance that the 747-8 will recieve a new number.
139, 306, 319, 320, 321, 332, 34A, AN2, AT4, AT5, AT7, 733, 735, 73G, 738, 739, 146, AR1, BH2, CN1, CR2, DH1, DH3, DH4,
Sooner787
Wed Feb 24, 2016 4:32 pm
Quoting larshjort (Reply 11):
VC-48 has a nice ring to it
Moose135
Wed Feb 24, 2016 7:36 pm
Quoting Sooner787 (Reply 12):
Which would work too, given the new tanker has the C-46 designation, this new airframe could end up as a C-48.
tjh8402
Thu Feb 25, 2016 12:06 am
Quoting Moose135 (Reply 13):
I notice y'all are skipping C-47. Think the USAF holds that in sufficient reverence that it's been officially retired? (recall that there was a previous C-46).
kanban
Thu Feb 25, 2016 2:41 am
is it a duller week in the sticks than usual... what they will number it is years away and probably the least important item available for discussion.. why don't we concentrate on how may of the normal 747-8i passenger windows will be blocked, or whether they will include a tarmac to mid deck elevator..
bikerthai
Thu Feb 25, 2016 2:17 pm
Quoting tjh8402 (Reply 14):
Another time, another place?
The C-47 was the Sky Train. But that was before the Air Force was created . . .
The USAF may not but the general public may . . . I do not believe any President would want to tread upon the memories of D-DAY and Band of Brothers . . .
bt
AviationAddict
Thu Feb 25, 2016 6:26 pm
Quoting bikerthai (Reply 16):
Both the C-46 and C-47 were designated prior to (and largely retired before) the introduction of the consolidated Tri-Service system in 1962. It is possible the USAF could skip the C-47 simply because of the history of the previous model but, in most cases designations are only skipped to avoid confusion with another type that is already in service or was recently retired. I think if they were to skip the C-47 their reasoning would be more to do with avoiding confusion with the Army CH-47 more so than an homage to the Douglas C-47.
  • 1
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
